05347777001
05347777001
    WERA(维拉)
05347777001 数据手册
160 i/168 i/6 Rack screwdriver set Kraftform Plus Series 100, and rack, 6 pieces Kraftform Plus – Series 100 VDE EAN: 4013288122957 Size: 285x210x55 mm Part number: 05347777001 Weight: 632 g Article number: 160 i/168 i/6 Rack Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Smooth hard zones for high speed turning, soft grip zones for high torque transfer Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Black Point tip for enhanced corrosion protection and an exact fit 6-piece screwdriver set with individually tested, insulated screwdrivers as per IEC 60900. Individual testing in a water bath at 10,000 volts so as to ensure safe working at the permitted voltage of 1,000 volts. Kraftform Plus handle for pleasant, ergonomic working that makes blisters and calluses a thing of the past. Hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. Partially Lasertip: the tip literally bites itself into the screw head and prevents any slipping. "Take it easy" Tool Finder: colour coding according to profile and size. The anti-roll feature prevents any bothersome rolling away at the workplace. Including a rack for storage. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_i_168_i_6_rack.html Wera - 160 i/168 i/6 Rack 05347777001 - 4013288122957 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 160 i/168 i/6 Rack screwdriver set Kraftform Plus Series 100, and rack, 6 pieces Kraftform Plus – Series 100 VDE Set contents: 162 i PH VDE 05006152001 05006154001 1 x PH 1x80 1 x PH 2x100 168 i VDE 05004780001 05004781001 1 x # 1x80 1 x # 2x100 Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. 160 i VDE 05006110001 05006120001 05006120001 1 x 0.6x3.5x100 1 x 1.0x5.5x125 1 x 1.0x5.5x125 Individually tested Impact strength test Lasertip Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Impact strength tested at −40°C, guaranteeing safety even under extreme conditions. A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip “bites” itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_i_168_i_6_rack.html Wera - 160 i/168 i/6 Rack 05347777001 - 4013288122957 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 160 i/168 i/6 Rack screwdriver set Kraftform Plus Series 100, and rack, 6 pieces Kraftform Plus – Series 100 VDE Reduced contact pressure “Take it easy” Toolfinder Multicomponent Kraftform handle Non-roll feature Wera Lasertip reduces the contact pressure required and enhances force transfer – meaning less screwdriving effort is required. Screwdriving becomes safer and easier. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. The hexagonal non-roll feature prevents any rolling away at the workplace. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_i_168_i_6_rack.html Wera - 160 i/168 i/6 Rack 05347777001 - 4013288122957 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05347777001 价格&库存
很抱歉,暂时无法提供与“05347777001”相匹配的价格&库存,您可以联系我们找货
