5073680001
5073680001
    WERA(维拉)
    WERA - 5073680001 - Screw Gripper Set, 165 mm x 60 mm x 24 mm, 2 Piece
5073680001 数据手册
1440/1442 Screw gripper set, 2 pieces Accessories EAN: 4013288140340 Size: 165x60x24 mm Part number: 05073680001 Weight: 17 g Article number: 1440/1442 Country of origin: CZ Customs tariff number: 39269097 Screw gripper set Attachment tool with holding function for screws Holds all screw profiles and sizes securely on the tool Made out of stable, elastomer material Screw gripper set: attachment tool with holding function for screws. Holds all screw profiles securely on the tool. During the job, the gripper can be pushed up along the blade so that it is not in the way when working with low-lying screws. Web link http://products.wera.de/en/screwdrivers_accessories_1440_1442.html Wera - 1440/1442 05073680001 - 4013288140340 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1440/1442 Screw gripper set, 2 pieces Accessories Set contents: 1440 05209885001 05209885001 1442 05209887001 1 x 4.5 - 6.0x41.0 1 x 4.5 - 6.0x41.0 1 x 6.0-8.5x41.0 And this is how the gripper works And this is how the gripper works And this is how the gripper works And this is how the gripper works Push the screw gripper onto the tip of the screwdriver until the end of the blade protrudes from the rubber blade holder. Attach the screw to the tip of the blade and secure it in the screw gripper. Pull the screw gripper towards the screwdriver handle until the two arms of the gripper sit against the head of the screw and are spread slightly apart. The Wera screw gripper releases the screw automatically after it has been fastened. The two gripper arms spread further apart as they are pushed against the surface and automatically snap back when the head of the screw is countersunk. And this is how the gripper works When fastening screws in blind holes the screw gripper is pushed back, making it possible to reach even deep-seated screws. Web link http://products.wera.de/en/screwdrivers_accessories_1440_1442.html Wera - 1440/1442 05073680001 - 4013288140340 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
5073680001 价格&库存
很抱歉,暂时无法提供与“5073680001”相匹配的价格&库存,您可以联系我们找货
