8100 SA 4
8100 SA 4
    WERA(维拉)
    WERA - 8100 SA 4 - 1/4" Drive 41 Piece Imperial Zyklop Ratchet Set in a High Density Foam-lined Meta...
8100 SA 4 数据手册
8100 SA 4 Zyklop Speed ratchet set, 1/4" drive, imperial, 41 pieces The Zyklop Ratchets, 1/4" EAN: 4013288121127 Size: 215x170x50 mm Part number: 05003535001 Weight: 1366 g Article number: 8100 SA 4 Country of origin: CZ Customs tariff number: 82041100 Combines five different types of a ratchet in one Flywheel design and easy-to-grip free-turning sleeve for very high working speeds 41-piece set in a robust metal case Freely pivoting ratchet head Take it easy tool finder with colour coding according to sizes 41-piece Zyklop starter set with the essential ratchet components in a robust metal case: Zyklop ratchet with 1/4"drive. The 72 fine-pitched teeth enable a low return angle of only 5°. The ratchet head pivots freely and can be locked into any position by using the slide switch that is positioned on either side. It is even possible to work conveniently in very confined and difficult-to-access areas with enhanced hand clearance. The predefined locking positions at 0°, 15° und 90°, both to the right and left, ensure safe working without any slipping of the ratchet head. The ratchet can be used as a conventional screwdriver in the 0° position by attaching an adaptor and a bit. The flywheel design ensures rapid screwdriving. The rotationsymmetric construction of the Kraftform handle and the free-turning sleeve support rapid twisting. The outstanding design of the Kraftform handle fits perfectly into the hand preventing hand injuries such as blisters and calluses. The hard materials used for the handle ensure quick and easy hand repositioning without any danger of the skin "sticking" to the handle. The softer anti-slip zones enable the low-loss transfer of high torque. For 1/4" square sockets as well as 1/4" adaptors with square drive, equipped with ball lock. Including 10 imperial Zyklop sockets, 2 Zyklop extensions with free-turning sleeve, 1 wobble extension, 1 T-handle, 1 universal joint, 1 adaptor with quick-release chuck, 24 bits. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_4_8100_sa_4.html Wera - 8100 SA 4 05003535001 - 4013288121127 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA 4 Zyklop Speed ratchet set, 1/4" drive, imperial, 41 pieces The Zyklop Ratchets, 1/4" Set contents: 8000 A 05003500001 1 x 1/4"x152.0 8790 HMA 05003514001 05003515001 05003516001 05003517001 05003518001 05003519001 05003520001 05003521001 05003522001 05003523001 1 x 3/16"x23.0 1 x 7/32"x23.0 1 x 1/4"x23.0 1 x 9/32"x23.0 1 x 5/16"x23.0 1 x 11/32"x23.0 1 x 3/8"x23.0 1 x 7/16"x23.0 1 x 1/2"x23.0 1 x 9/16"x23.0 8789 A 05003524001 1 x 1/4"x110.0 8794 A 05003527001 1 x 1/4"x56.0 8795 A 05003528001 1 x 1/4"x35.5 8784 A1 05003529001 1 x 1/4"x37.0 8796 SA 05003530001 1 x 1/4"x75.0 8796 LA 05003531001 1 x 1/4"x150.0 851/1 Z PH 05072070001 05072072001 05072074001 1 x PH 1x25 1 x PH 2x25 1 x PH 3x25 855/1 Z PZ 05072080001 05072082001 05072084001 1 x PZ 1x25 1 x PZ 2x25 1 x PZ 3x25 867/1 Z TORX® BO 05066498001 1 x TX 8x25 05066499001 1 x TX 9x25 05066500001 1 x TX 10x25 05066505001 1 x TX 15x25 05066510001 1 x TX 20x25 05066515001 1 x TX 25x25 05066525001 1 x TX 30x25 05066530001 1 x TX 40x25 800/1 Z 05072055001 05072059001 05072063001 840/1 Z Hex-Plus 05135069001 1 x 9/64x25 05135071001 1 x 5/64x25 05135072001 1 x 3/32x25 05135073001 1 x 1/8x25 05135074001 1 x 5/32"x25 05135075001 1 x 3/16"x25 05135079001 1 x 7/32"x25 1 x 0.6x4.5x25 1 x 1.0x5.5x25 1 x 1.2x8.0x25 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_4_8100_sa_4.html Wera - 8100 SA 4 05003535001 - 4013288121127 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA 4 Zyklop Speed ratchet set, 1/4" drive, imperial, 41 pieces The Zyklop Ratchets, 1/4" Zyklop “6 in 1” Pivots freely Fast movers Incredibly fast ¼” Zyklop Speed ratchet with pivoting ratchet head and 5 predefined locking positions 1. Fine-tooth ratchet 2. Flex-head ratchet 3. Angle ratchet 4. Quickrelease ratchet 5. Power ratchet 6. Screwdriver The ratchet head pivots freely and can be locked into any defined position by using the slide switch that is positioned on either side. It is even possible to work in very confined and difficult-to-access areas with enhanced hand clearance. The predefined locking at 0°, 15° and 90°, both to the right and left, ensure safe working without any slipping of the ratchet head. The Zyklop Speed ratchets are really fast movers. The gyrating mass design means that screwdriving is accelerated. The rotation-symmetric structure of the Kraftform handle and the freeturning sleeve reinforce this rapid twisting process, particularly when the ratchet does not engage due to too little resistance in the thread. Simple direction change Low return angle Screwdriver Two-tone foam insert All Zyklop Speed ratchets feature a thumbwheel that can be used to quickly and easily switch between clockwise and anticlockwise rotation, at any position. No complicated handling, no loss of time! The reversible ratchet with 72 finepitched teeth has a low return angle of only 5°. This short stroke allows fast and precise work in all types of installation. The ratchet can be used as a conventional screwdriver in the 0° position by attaching a bitholding adaptor and a bit. Perfectly conceived in every detail: the storage case for the Zyklop Speed ratchet sets! The two-tone foam insert section means that the tools can be quickly and reliably replaced, and that missing tools can be detected immediately. The tools and their position can be clearly seen in the lid where they have been laser-etched, ensuring that they are legible even when the insert section is covered with grease, dirt or oil. Additionally, the foam section can be removed and placed in the drawer of a tool cabinet or trolley. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_4_8100_sa_4.html Wera - 8100 SA 4 05003535001 - 4013288121127 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA 4 Zyklop Speed ratchet set, 1/4" drive, imperial, 41 pieces The Zyklop Ratchets, 1/4" Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_4_8100_sa_4.html Wera - 8100 SA 4 05003535001 - 4013288121127 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8100 SA 4 价格&库存
很抱歉,暂时无法提供与“8100 SA 4”相匹配的价格&库存,您可以联系我们找货
