8100 SB 2
8100 SB 2
    WERA(维拉)
    WERA - 8100 SB 2 - 3/8" Drive 43 Piece Metric Zyklop Ratchet Set in a High Density Foam-lined Metal ...
8100 SB 2 数据手册
8100 SB 2 Zyklop Speed ratchet set, 3/8" drive, metric, 43 pieces The Zyklop Ratchets, 3/8" EAN: 4013288121141 Size: 295x245x60 mm Part number: 05003594001 Weight: 3510 g Article number: 8100 SB 2 Country of origin: CZ Customs tariff number: 82041100 Combines five different types of a ratchet in one Flywheel design and easy-to-grip free-turning sleeve for very high working speeds 43-piece set in a robust metal case Freely pivoting ratchet head Take it easy tool finder with colour coding according to sizes 43-piece Zyklop set in robust metal case: Zyklop ratchet with 3/8"drive. The 72 fine-pitched teeth enable a low return angle of only 5°. The ratchet head pivots freely and can be locked into any position by using the slide switch that is positioned on either side. It is even possible to work conveniently in very confined and difficult-to-access areas with enhanced hand clearance. The predefined locking positions at 0°, 15° und 90°, both to the right and left, ensure safe working without any slipping of the ratchet head. The ratchet can be used as a conventional screwdriver in the 0° position by attaching an adaptor and a bit. The flywheel design ensures rapid screwdriving. The rotation-symmetric construction of the Kraftform handle and the free-turning sleeve support rapid twisting. The outstanding design of the Kraftform handle fits perfectly into the hand preventing hand injuries such as blisters and calluses. The hard materials used for the handle ensure quick and easy hand repositioning without any danger of the skin "sticking" to the handle. The softer anti-slip zones enable the low-loss transfer of high torque. For 3/8" square sockets as well as 3/8" adaptors with square drive, equipped with ball lock. Including 18 Zyklop sockets, 2 Zyklop extensions with free-turning sleeve, 1 T-handle, 1 wobble extension, 1 universal joint, 1 adaptor with quick-release chuck, 18 bits. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_2.html Wera - 8100 SB 2 05003594001 - 4013288121141 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 2 Zyklop Speed ratchet set, 3/8" drive, metric, 43 pieces The Zyklop Ratchets, 3/8" Set contents: 8000 B 05003550001 1 x 3/8"x199.0 8790 HMB 05003551001 05003552001 05003553001 05003554001 05003555001 05003556001 05003557001 05003558001 05003559001 05003560001 05003561001 05003562001 05003563001 05003564001 05003565001 05003566001 05003567001 05003568001 1 x 6.0x29.0 1 x 7.0x29.0 1 x 8.0x29.0 1 x 9.0x29.0 1 x 10.0x29.0 1 x 11.0x29.0 1 x 12.0x29.0 1 x 13.0x29.0 1 x 14.0x29.0 1 x 15.0x29.0 1 x 16.0x30.0 1 x 17.0x30.0 1 x 18.0x30.0 1 x 19.0x30.0 1 x 20.0x30.0 1 x 21.0x30.0 1 x 22.0x30.0 1 x 24.0x32.0 8789 B 05003581001 1 x 3/8"x165.0 8794 B 05003584001 1 x 3/8"x76.0 8795 B 05003585001 1 x 3/8"x50.0 8784 B1 05003590001 1 x 1/4"x3/8"x44.0 8796 SB 05003591001 1 x 3/8"x125.0 8796 LB 05003592001 1 x 3/8"x200.0 851/1 Z PH 05072072001 05072074001 1 x PH 2x25 1 x PH 3x25 855/1 Z PZ 05072082001 05072084001 1 x PZ 2x25 1 x PZ 3x25 867/1 Z TORX® BO 05066500001 1 x TX 10x25 05066505001 1 x TX 15x25 05066510001 1 x TX 20x25 05066515001 1 x TX 25x25 05066520001 1 x TX 27x25 05066525001 1 x TX 30x25 05066530001 1 x TX 40x25 800/1 Z 05072059001 840/1 Z Hex-Plus 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 05056335001 1 x 8.0x25 05056340001 1 x 10.0x25 1 x 1.0x5.5x25 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_2.html Wera - 8100 SB 2 05003594001 - 4013288121141 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 2 Zyklop Speed ratchet set, 3/8" drive, metric, 43 pieces The Zyklop Ratchets, 3/8" The Zyklop Speed Ratchet Pivots freely Fast movers Incredibly fast ¼” Zyklop Speed ratchet with pivoting ratchet head and 5 predefined locking positions The Wera Zyklop Speed ratchet combines the advantages of five different types of ratchet in one. And it is a really fast mover. The ratchet head pivots freely and can be locked into any defined position by using the slide switch that is positioned on either side. It is even possible to work in very confined and difficult-to-access areas with enhanced hand clearance. The predefined locking at 0°, 15° and 90°, both to the right and left, ensure safe working without any slipping of the ratchet head. The Zyklop Speed ratchets are really fast movers. The gyrating mass design means that screwdriving is accelerated. The rotation-symmetric structure of the Kraftform handle and the freeturning sleeve reinforce this rapid twisting process, particularly when the ratchet does not engage due to too little resistance in the thread. Simple direction change Low return angle Screwdriver Two-tone foam insert All Zyklop Speed ratchets feature a thumbwheel that can be used to quickly and easily switch between clockwise and anticlockwise rotation, at any position. No complicated handling, no loss of time! The reversible ratchet with 72 finepitched teeth has a low return angle of only 5°. This short stroke allows fast and precise work in all types of installation. The ratchet can be used as a conventional screwdriver in the 0° position by attaching a bitholding adaptor and a bit. Perfectly conceived in every detail: the storage case for the Zyklop Speed ratchet sets! The two-tone foam insert section means that the tools can be quickly and reliably replaced, and that missing tools can be detected immediately. The tools and their position can be clearly seen in the lid where they have been laser-etched, ensuring that they are legible even when the insert section is covered with grease, dirt or oil. Additionally, the foam section can be removed and placed in the drawer of a tool cabinet or trolley. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_2.html Wera - 8100 SB 2 05003594001 - 4013288121141 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 2 Zyklop Speed ratchet set, 3/8" drive, metric, 43 pieces The Zyklop Ratchets, 3/8" Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_2.html Wera - 8100 SB 2 05003594001 - 4013288121141 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8100 SB 2 价格&库存
很抱歉,暂时无法提供与“8100 SB 2”相匹配的价格&库存,您可以联系我们找货
