BC IMPAKTOR/30 BIT-CHECK
    WERA(维拉)
    WERA - BC IMPAKTOR/30 BIT-CHECK - Bit Set, Impaktor, 25mm Drive, 30 Piece
BC IMPAKTOR/30 BIT-CHECK 数据手册
Bit-Check 30 Impaktor 1, 30 pieces Bit-Checks Impaktor EAN: 4013288156778 Size: 165x85x35 mm Part number: 05057690001 Weight: 274 g Article number: Bit-Check 30 Impaktor 1 Country of origin: CZ Customs tariff number: 82079030 Upright positionable, multi-component Bit-Check Impaktor technology for above-average service life Particularly suitable for use with customary impact drivers Diamond coating for a secure fit in the screw, literally bites into the screwhead to prevent cam-out Holder with ring magnet for holding longer and heavier screws 1 Impaktor holder with retaining ring and ring magnet, 29 Impaktor bits. The Impaktor technology offers an above-average service life even under extreme circumstances thanks to the best possible utilisation of the material properties and the optimised geometry; particularly suitable for use with customary impact drivers; holder with ring magnet for simple holding of even longer and heavier screws, ideal for overhead work. The rough diamondcoating of the bits reduces the risk of a slipping out of the screw head thanks to the enhanced frictional resistance. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_impaktor_bit-check_30_impaktor_1.html Wera - Bit-Check 30 Impaktor 1 05057690001 - 4013288156778 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Impaktor 1, 30 pieces Bit-Checks Impaktor Set contents: 897/4 Impaktor R 05057676001 1 x 1/4"x75 851/1 IMP DC 05057615001 05057616001 05057617001 2 x PH 1x25 3 x PH 2x25 2 x PH 3x25 855/1 IMP DC 05057620001 05057621001 05057622001 2 x PZ 1x25 3 x PZ 2x25 2 x PZ 3x25 867/1 IMP DC 05057628001 05057623001 05057624001 05057625001 05057626001 05057627001 1 x TX 10x25 1 x TX 15x25 2 x TX 20x25 3 x TX 25x25 2 x TX 30x25 2 x TX 40x25 840/1 IMP DC 05057603001 05057604001 05057605001 05057606001 1 x 3.0x25 1 x 4.0x25 1 x 5.0x25 1 x 6.0x25 Impaktor technology for an aboveaverage service life even under extreme demands At the workplace Improved productivity Above-average service life The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. For use with impact screwdrivers. Improve productivity when screwdriving with power tools. Maximum utilisation of the material properties, a very special geometry – designed particularly to meet the extreme demands – as well a specific manufacturing process mean that Wera Impaktor tools have an above-average service life. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_impaktor_bit-check_30_impaktor_1.html Wera - Bit-Check 30 Impaktor 1 05057690001 - 4013288156778 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Impaktor 1, 30 pieces Bit-Checks Impaktor Torsion zone Impaktor-Bits Impaktor holder with ring magnet TriTorsion system Torsion zone specially designed to absorb such forces and thereby protect the bit tip. For an above-average service life. Maximum utilisation of the material properties, a very special geometry – designed particularly to meet the extreme demands – as well a specific manufacturing process mean that Wera Impaktor tools have an above-average service life. Another product advantage is the coating of the Impaktor bits with minute diamond particles. These diamond particles reduce the cam-out effects – particularly high in power tool applications – which can lead to a slipping out of the screw head. The diamond particles literally bite themselves into the screw recess. This means that less contact pressure is required, something that greatly delays fatigue settingin in power tool screwdriving jobs. The Impaktor holder with ring magnet additionally holds longer and heavier screws absolutely securely. This enables a speedy and dependable positioning of the screw. It is also ideal for abovehead work. Should the magnet function not be required in a particular situation e.g. when working with metal, it can be extracted from the screwdriving area and can thereby be “disabled”. Mainly used in manual power tool applications. The combination of the double torsion zones in the Impaktor holder and the torsion zone in the Impaktor bit result in the so-called TriTorsion system. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_impaktor_bit-check_30_impaktor_1.html Wera - Bit-Check 30 Impaktor 1 05057690001 - 4013288156778 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
BC IMPAKTOR/30 BIT-CHECK 价格&库存
很抱歉,暂时无法提供与“BC IMPAKTOR/30 BIT-CHECK”相匹配的价格&库存,您可以联系我们找货
