002990
002990
    WERA(维拉)
002990 数据手册
88/1 Vario set, 11 pieces Kraftform Kompakt Vario without Ratchet Function EAN: 4013288000675 Size: 210x105x50 mm Part number: 05002990001 Weight: 629 g Article number: 88/1 Country of origin: CZ Customs tariff number: 82054000 Vario set with handle and 10 combination blades Smooth hard zones for high speed turning, soft grip zones for high torque transfer Chrome-plated hexagonal blade material, 6 mm Black Point tip offers a perfect fit with optimised corrosion protection In a robust belt pouch 11-piece Vario set with handle and blades. In a practical belt pouch, enabling the tools to be safely and securely stored and to always be at hand. The Kraftform grip on the handle stands for pleasant, ergonomic working and makes blisters and calluses a thing of the past. Hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. The hexagonal non-roll feature prevents any annoying rolling away at the workplace. The integrated hex bolster allows higher torque to be applied with an open-end or ring spanner. The double blades are out of high quality bit material and are therefore particularly durable. The Wera Black Point tip on the blade offers a perfect fit and optimised corrosion protection. Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_vario_without_ratchet_function_6_mm_vario_blades_and_adaptors_88_1.html Wera - 88/1 05002990001 - 4013288000675 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 88/1 Vario set, 11 pieces Kraftform Kompakt Vario without Ratchet Function Set contents: 80 05002900001 1 x 6x98 86 05002960001 1 x PZ 1xPZ 2x175 81 05002910001 05002913001 1 x 0.6x4.0x1.0x6.0x175 1 x 0.8x5.0x1.2x7.0x175 85 05002950001 1 x PH 1xPH 2x175 87 05002970001 05002973001 05002976001 1 x TX 10xTX 15x175 1 x TX 20xTX 25x175 1 x TX 30xTX 40x175 84 05002940001 05002943001 05002946001 1 x 4x175 1 x 5x175 1 x 6x175 Handle/interchangeable blade system Vario double-ended blades Kraftform Prevents hand injuries The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. The 6 mm double-ended blades of 175 mm length are out of high quality bit material which gives them a particularly long service life. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_vario_without_ratchet_function_6_mm_vario_blades_and_adaptors_88_1.html Wera - 88/1 05002990001 - 4013288000675 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
002990 价格&库存
很抱歉,暂时无法提供与“002990”相匹配的价格&库存,您可以联系我们找货
