00C93410101
00C93410101
    CCI
00C93410101 数据手册
CCIC BGA heat sinks - Aluminium BGA and compact crosscut heat sinking for a variety of applications requiring simple extension of surface area for cooling. Typically used with DSP, FPGAs, and other electronics packages. Double sided adhesive provides simple and effective attachment Technical specifications: 10 Thermal resistance (sink to ambient) K / W at 0.3 m/s 7.93 Thermal resistance (sink to ambient) K / W at 1.0 m/s 3.57 9 9.51 5.29 9 9.96 5.87 CCI10 38 6 9.12 4.65 00C845401A 25 10 9.6 5.3 CCI11 40 5 9.38 5.14 Width & Length Height CCI02 45 CCI08 28 CCI09 30 Part Number CCI Heat Pipes - - Copper heat pipes, pure water filled for operation between +5 degC and 110 degC. Various wick structures offered, Screen mesh, Grooved, Sintered and composite (G+S) Low thermal resistance for transportation of heat from hot source to exchanger. Heat pipe can be incorporate into a block and fix a finned structure (or heat sink) to allow effective heat removal. Thermal resistance of pipe taken at 70degC working temperature (adiabatic), under horizontal orientation, evaporator section 15mm, and condensation section 60mm Structure Length Original Diameter Thickness 00C93390101 Sintered 100 5 5 Thermal resistance of pipe Rpipe in (K / W) 0.02 – 0.04 00C93400101 Sintered 150 6 6 0.02 – 0.03 65 00C93410101 SM 150 4 2 0.65 – 0.90 15 30 Part Number Operating Max Power (W) 40 00C93420101 SM 200 6 2 0.35 – 0.60 00C93430101 Groove 100 5 2.5 0.03 – 0.06 30 00C93440101 Groove 150 6 6 0.02 – 0.03 65 00C93450101 Groove 150 8 2.5 0.003 – 0.05 15 00C93460101 G+S 200 6 3.0 0.003 – 0.008 40 00C93470101 G+S 150 8 4.5 0.003 – 0.015 70 00C93480101 G+S 300 8 8 0.002 – 0.007 65 Design Guidelines (1) Groove heatpipe condenser heatpipe condenser evaporator - 90 deg 0 deg evaporator Heat source • The heatpipe performance is without change from -90 deg to 0 deg. Larger than 0 deg (i.e. evaporator is higher than condenser), the performance of grooved pipe will degrade 50%. (2) Mesh heatpipe condenser evaporator heatpipe 30 deg - 90 deg condenser evaporator Heat source • Larger than 30 deg, the performance of mesh pipe will degrade 50%. (3) Sintered Powder heatpipe • The orientation has no impact on the sintered powder heatpipe performance.
00C93410101 价格&库存
很抱歉,暂时无法提供与“00C93410101”相匹配的价格&库存,您可以联系我们找货
