010-0115
010-0115
    ANTISTAT
    ANT010SSB Series 11 x 15 inch 4 Layer Metal Static Shielding Bag - 100 bags/pack
010-0115 数据手册
ANTISTAT.CO.UK | INFO@ANTISTAT.CO.UK | +44 (0)1473 836 200 TECHNICAL DATASHEET Static Shielding Bag ANT010SSB Description These open top, easy access static shielding bags are designed to protect sensitive electronic devices against ESD during transit and whilst kept in storage. Features • Metal “Faraday cage” layer shields products from electric energy inside and prevents static build-up • Four layer protection guards against charges inside and out • Semi transparent for easy content identification • Surface resistance of 108-1011Ω • Conforms to EIA 625, EIA 541, ANSI/ESD S-20.20 & EN61340-51-ESD • Custom sizes and print available on request • Suitable for packing electronic products which are sensitive to static, eg PCBs, electronic components etc 1 Bag Opening Length Seal Seal 1 2 2 3 Bottom Fold or Seal Width 3 Configuration(s) Our bags are available in custom sizes or in several industry standard sizes. Bags are offered in a 2-seal configuration and bottom fold, with our standard flexographically printed artwork. Please note any bags that are longer than 24” will have a 3rd seal along the bottom edge. Our bags can also be personalised with your company logo on any bespoke orders. Standard Bag Artwork Our static shielding bags are produced with the following sample artwork as standard. For further information on bespoke/printed orders, please contact one of our sales team. Please note there is a MOQ of 20,000 bags on all printed bags. Construction Our static shielding bags are constructed in four layers, consisting of a static dissipative polyester outer layer and a static dissipative polyethylene inner layer with a centre metallised shield layer. Our bags are manufactured from industry approved polyester and polyethelene laminates. The polyester dielectric works with the metal layer to provide a Faraday effect, the metal layer preventing penetration from damaging electrostatic fields. The specially processed polyethelene keeps tribocharging to a minimum. Important Notice: This data sheet and its contents (the “Information”) belong to Antistat or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Antistat assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Antistat was aware of the possibility of such loss or damage arising) is excluded. © Antistat . ant010ssb-static-shielding-bag | December 18, 2017 3:19 PM WWW.ANTISTAT.CO.UK PAGE ANTISTAT.CO.UK | INFO@ANTISTAT.CO.UK | +44 (0)1473 836 200 TECHNICAL DATASHEET Static Shielding Bag ANT010SSB Test Conditions The following results were taken under the following environmental test conditions: Temperature: 23oC / Humidity: 12% RH Technical Parameters: Item Test Standard Result Film Thickness Micron Meter 3mils 75 micron Metal Layer Optical Transmission ASTM D1003 (TOBIAS) 40% +/- 5% optical density Surface Resistivity STM 11.11
010-0115 价格&库存
很抱歉,暂时无法提供与“010-0115”相匹配的价格&库存,您可以联系我们找货
  • 1+392.585491+50.81610
  • 5+314.016025+40.64610
