013-0005
013-0005
    ANTISTAT
    ANT013SSB Series 6x10 inch 4 Layer Static Shielding Ziplock Bag - 100 bags/pack
013-0005 数据手册
ANTISTAT.CO.UK | INFO@ANTISTAT.CO.UK | +44 (0)1473 836 200 TECHNICAL DATASHEET Static Shielding Ziplock Bag ANT013SSB Description An anti-static shielding ziplock/gripseal bag providing full protection against ESD. This bag is designed to give ultimate protection against static damage to electronic components and devices whilst being handled in storage and during transportation. Features • Metal “Faraday cage” layer shields products from electric energy inside and prevents static build-up • Four layer protection guards against charges inside and out • Semi transparent for easy content identification • Surface resistance of 106-1010Ω/sq • Conforms to EIA 625, EIA 541, ANSI/ESD S-20.20 • Custom sizes and print available on request • Suitable for packing electronic products which are sensitive to static, eg PCBs, electronic components etc 1 Bag Opening Length Seal Seal 1 Width 3 Our bags are available in custom sizes or in several industry standard sizes. Bags are offered in a 2-seal configuration and bottom fold, with our standard flexographically printed artwork. Please note any bags that are longer than 24” will have a 3rd seal along the bottom edge. 2 Standard Bag Artwork 3 Construction 2 Bottom Fold or Seal Configuration(s) Our static shielding bags are produced with the following sample artwork as standard. For further information on bespoke/printed orders, please contact one of our sales team. Our static shielding bags are constructed in four layers, consisting of a static dissipative polyester outer layer and a static dissipative polyethylene inner layer with a centre metallised shield layer. Our bags are manufactured from industry approved polyester and polyethelene laminates. The polyester dielectric works with the metal layer to provide a Faraday effect, the metal layer preventing penetration from damaging electrostatic fields. The specially processed polyethelene keeps tribocharging to a minimum. Important Notice: This data sheet and its contents (the “Information”) belong to Antistat or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Antistat assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Antistat was aware of the possibility of such loss or damage arising) is excluded. © Antistat . ant013ssb-static-shielding-bag-ziplock | January 3, 2018 5:13 PM WWW.ANTISTAT.CO.UK ANTISTAT.CO.UK | INFO@ANTISTAT.CO.UK | +44 (0)1473 836 200 TECHNICAL DATASHEET Static Shielding Ziplock Bag ANT013SSB Test Conditions The following results were taken under the following environmental test conditions: Temperature: 23oC / Humidity: 12% RH Technical Parameters Item Test Standard Result Film Thickness Micron Meter 3mils 75 micron Metal Layer Optical Transmission ASTM D1003 (TOBIAS) 40% +/- 5% optical density Surface Resistivity STM 11.11 �106 Ω
013-0005 价格&库存
很抱歉,暂时无法提供与“013-0005”相匹配的价格&库存,您可以联系我们找货
  • 1+173.155081+22.50960
  • 5+138.471915+18.00090
库存:28
