ANTISTAT.CO.UK | INFO@ANTISTAT.CO.UK | +44 (0)1473 836 200
TECHNICAL DATASHEET
Static Shielding Ziplock Bag
ANT013SSB
Description
An anti-static shielding ziplock/gripseal bag providing full protection
against ESD. This bag is designed to give ultimate protection against
static damage to electronic components and devices whilst being
handled in storage and during transportation.
Features
• Metal “Faraday cage” layer shields products from electric
energy inside and prevents static build-up
• Four layer protection guards against charges inside and out
• Semi transparent for easy content identification
• Surface resistance of 106-1010Ω/sq
• Conforms to EIA 625, EIA 541, ANSI/ESD S-20.20
• Custom sizes and print available on request
• Suitable for packing electronic products which are sensitive
to static, eg PCBs, electronic components etc
1
Bag Opening
Length
Seal
Seal
1
Width
3
Our bags are available in custom sizes or in several industry
standard sizes.
Bags are offered in a 2-seal configuration and bottom fold,
with our standard flexographically printed artwork. Please
note any bags that are longer than 24” will have a 3rd seal
along the bottom edge.
2
Standard Bag Artwork
3
Construction
2
Bottom Fold or Seal
Configuration(s)
Our static shielding bags are produced with the following
sample artwork as standard. For further information on
bespoke/printed orders, please contact one of our sales
team.
Our static shielding bags are constructed in four layers,
consisting of a static dissipative polyester outer layer and
a static dissipative polyethylene inner layer with a centre
metallised shield layer.
Our bags are manufactured from industry approved
polyester and polyethelene laminates. The polyester
dielectric works with the metal layer to provide a Faraday
effect, the metal layer preventing penetration from
damaging electrostatic fields. The specially processed
polyethelene keeps tribocharging to a minimum.
Important Notice: This data sheet and its contents (the “Information”) belong to Antistat or are licensed to it. No licence is granted for the use of it other than for
information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Antistat assumes no responsibility for its accuracy
or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the
products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the
Information or use of it (including liability resulting from negligence or where Antistat was aware of the possibility of such loss or damage arising) is excluded. © Antistat .
ant013ssb-static-shielding-bag-ziplock | January 3, 2018 5:13 PM
WWW.ANTISTAT.CO.UK
TECHNICAL DATASHEET
ANT013SSB
Test Conditions
The following results were taken under the following environmental test conditions:
Temperature: 23oC / Humidity: 12% RH
Technical Parameters
Item
Test Standard
Result
Film Thickness
Micron Meter
3mils 75 micron
Metal Layer Optical Transmission
ASTM D1003 (TOBIAS)
40% +/- 5% optical density
Surface Resistivity
STM 11.11
�106 Ω
很抱歉,暂时无法提供与“013-0008”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+299.283611+38.90590
- 5+239.479045+31.13150
