010-0036
010-0036
    ANTISTAT
    ANT010SSB Series 8 x 18 inch 4 Layer Metal Static Shielding Bag - 100 bags/pack
010-0036 数据手册
antistat.com | sales@antistat.com | +1 512-243-5762 TECHNICAL DATASHEET Static Shielding Bag_ANT010SSB Features: • Metal “Faraday cage” layer shields products from electric energy inside and prevents static build-up • Four layer protection guards against charges inside and out • Semi transparent for easy content identification • Surface resistance of 108-1011Ω • Conforms to ANSI/ESD S-20.20, EN61340-5-1, ANSI/ESD STM11.31 • Custom sizes and print available on request • Suitable for packing electronic products which are sensitive to static, eg PCB’s, Electronic Components etc Construction: Our static shielding bags are constructed in four layers, consisting of a static dissipative polyester outer layer and a static dissipative polyethylene inner layer with a centre metallised shield layer. Outer Surface Dissipative Layer Aluminized Polyester Polyethylene Inner Surface Dissipative Layer Our bags are manufactured from industry approved polyester and polyethelene laminates. The polyester dielectric works with the metal layer to provide a Faraday effect, the metal layer preventing penetration from damaging electrostatic fields. The specially processed polyethelene keeps tribocharging to a minimum. ANT010SSB_Artwork_Open Top_May11.pdf Seal 1 08/12/2015 Length Seal Bag Opening Configuration(s): Our bags are available in custom sizes or in several industry standard sizes. Bags are offered in a 2-seal configuration and bottom fold, with our standard flexographically printed artwork. Please note any bags that are longer than 24” will have a 3rd seal along the bottom edge. Our bags can also be personalised with your company logo on any bespoke orders. 15:04 Bottom Fold Width C M Y CM MY CY CMY K S Standard Bag Artwork: Our static shielding bags are produced with the following sample artwork as standard. For further information on bespoke/printed orders, please contact one of our sales team. Please note there is a MOQ of 20,000 bags on all printed bags. Important Notice: This data sheet and its contents (the “Information”) belong to Antistat Inc. or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Antistat Inc. assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Antistat Inc. was aware of the possibility of such loss or damage arising) is excluded. © Antistat Inc. 2016. ANT010SSB_Static Shielding Bag-open-top-USA | January 4, 2017 1:56 PM PAGE antistat.com | sales@antistat.com | +1 512-243-5762 TECHNICAL DATASHEET Static Shielding Bag_ANT010SSB Test Conditions: The following results were taken under the following environmental test conditions: Temperature: 23oC / Humidity: 12% RH Technical Parameters: Item: Test Standard: Result: Film Thickness Micron Meter 3mil 75 micron Metal Layer Optical Transmission ASTM D1003 (TOBIAS) 40% +/- 5% optical density Surface Resistivity STM 11.11
010-0036 价格&库存
很抱歉,暂时无法提供与“010-0036”相匹配的价格&库存,您可以联系我们找货
  • 1+355.947621+46.02490
  • 5+284.810535+36.82670
