ANTISTAT.CO.UK | INFO@ANTISTAT.CO.UK | +44 (0)1473 836 200
TECHNICAL DATASHEET
Static Shielding Bag
ANT010SSB
Description
These open top, easy access static shielding bags are designed to protect
sensitive electronic devices against ESD during transit and whilst kept in
storage.
Features
• Metal “Faraday cage” layer shields products from electric
energy inside and prevents static build-up
• Four layer protection guards against charges inside and out
• Semi transparent for easy content identification
• Surface resistance of 108-1011Ω
• Conforms to EIA 625, EIA 541, ANSI/ESD S-20.20 & EN61340-51-ESD
• Custom sizes and print available on request
• Suitable for packing electronic products which are sensitive
to static, eg PCBs, electronic components etc
1
Bag Opening
Length
Seal
Seal
1
2
2
3
Bottom Fold or Seal
Width
3
Configuration(s)
Our bags are available in custom sizes or in several industry
standard sizes. Bags are offered in a 2-seal configuration and
bottom fold, with our standard flexographically printed artwork.
Please note any bags that are longer than 24” will have a 3rd seal
along the bottom edge. Our bags can also be personalised with
your company logo on any bespoke orders.
Standard Bag Artwork
Our static shielding bags are produced with the following sample
artwork as standard. For further information on bespoke/printed
orders, please contact one of our sales team. Please note there is
a MOQ of 20,000 bags on all printed bags.
Construction
Our static shielding bags are constructed in four layers,
consisting of a static dissipative polyester outer layer and a static
dissipative polyethylene inner layer with a centre metallised shield
layer.
Our bags are manufactured from industry approved polyester
and polyethelene laminates. The polyester dielectric works with
the metal layer to provide a Faraday effect, the metal layer
preventing penetration from damaging electrostatic fields.
The specially processed polyethelene keeps tribocharging to a
minimum.
Important Notice: This data sheet and its contents (the “Information”) belong to Antistat or are licensed to it. No licence is granted for the use of it other than for
information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Antistat assumes no responsibility for its accuracy
or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the
products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the
Information or use of it (including liability resulting from negligence or where Antistat was aware of the possibility of such loss or damage arising) is excluded. © Antistat .
ant010ssb-static-shielding-bag | December 18, 2017 3:19 PM
WWW.ANTISTAT.CO.UK
PAGE
TECHNICAL DATASHEET
ANT010SSB
Test Conditions
The following results were taken under the following environmental test conditions:
Temperature: 23oC / Humidity: 12% RH
Technical Parameters:
Item
Test Standard
Result
Film Thickness
Micron Meter
3mils 75 micron
Metal Layer Optical Transmission
ASTM D1003 (TOBIAS)
40% +/- 5% optical density
Surface Resistivity
STM 11.11
