0110765
0110765
    DURATOOL
0110765 数据手册
Flat Washers Features: • • • • • Moulded or stamped in nylon 6.6 Provides electrical insulation Ideal for use as a bearing surface Will not corrode Good chemical resistance Specifications: Material Tolerances : Nylon 66 : Outside diameter, inside diameter and T = ±0.26 Specification Table Nominal Size Outside Diameter Inside Diameter T Part Number M2 5 2.15 0.8 0110763 M2.5 5.6 2.65 0.8 0110764 M3 8 3.2 0.8 0110765 M4 9 4.3 0.8 0110767 M5 11 5.3 1 0110768 M6 12 6.4 1.5 0110769 M8 18 8.4 2 0110770 M10 22 10.5 2.5 0110771 Dimensions : Millimetres Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 19/04/12 V1.1
0110765 价格&库存
很抱歉,暂时无法提供与“0110765”相匹配的价格&库存,您可以联系我们找货
