D00675
D00675
    DURATOOL
D00675 数据手册
Soldering Station Features: •  Temperature controlled •  The soldering station is an ideal soldering tool for hobbyist or occasional use •  It has the function of regulating temperature, 1°C or 10°C per grade can be regulated using the control buttons •  Preset buttons of 200, 300 and 400 are also included •  The station can be switched between °C and °F •  Contents of station: power unit, soldering iron (with a conical tip), user instructions Specifications: Power Supply Voltage Electric Iron Power Equipment Power Supply Fuse Regulating Scope of Temperature Temperature Display Display Scope Display Precision Circumstance Humidity Relative Humidity Atmospheric Pressure Shell Size (W × H × D) Weight :1  10V (110V to 130V) / 60 Hz 230V (220V to 240V) / 50 Hz : 48W : T1A / 250V (50mm × 20mm glass pipe) : 150°C to 450°C : 2 × 3-1/2 grades LCD display : 150°C to 450°C : 5% : +5°C to +40°C :
D00675 价格&库存
很抱歉,暂时无法提供与“D00675”相匹配的价格&库存,您可以联系我们找货
