D01628
D01628
    DURATOOL
D01628 数据手册
Electronic Cutters and Pliers Kit 6 Pieces Ì High quality ball bearing steel Ì 63 - 65 Rockwell Hardness (HRC): Pyrometer controlled inductive hardening Ì All cutters available with three types of cutting blades: - SEMI-FLUSH, for soft and hard wire - FLUSH, for very precise cutting of soft wire - FULL-FLUSH, for a perfect cutting of soft wire Ì 2-Component ESD Ergonomic handles, soft comfortable gripping surface, hard plastic core Ì Dual leaf springs in blue steal Ì Matched bearing rings in order to minimize metal-metal contact and friction Ì Lap joint with screw in order to achieve a high level of strength and precision. The nut is made of hardened alloy steel in order to resist high cutting load. The screw is fine-pitched for perfect joint adjustment Ì Kit Content: - Oval Small Semi-Flush cutters - Oval Big Semi-Flush cutters - Tapered Small Flush cutters - Tapered and relieved Full-Flush cutters - Snipe Long Nose pliers - Round Nose pliers 551097 Mftrs. Description List No. Order Code ELECTRONIC PLIERS + CUTTERS SET, 6PC D01628 177-2127 + — — Price Each + — — + — —
D01628 价格&库存
很抱歉,暂时无法提供与“D01628”相匹配的价格&库存,您可以联系我们找货
