D01854
D01854
    DURATOOL
D01854 数据手册
Solder and Repair Kit UK Plug Features •  •  •  •  20W and 30W versions available Integral hanging hook Ceramic heating element Replacement tips available Contents •  Soldering iron with spare tip •  Desoldering pump, with spate nozzle and piston ring •  Long nose plier, 4.5″ •  Diagonal cutting plier, 4.5″ •  Voltage tester •  Screwdriver (+) 5mm × 100mm •  Holder •  Multimeter •  Solder Technical Specification Supply Voltage 230V (220V - 240V) / 50Hz Electric Iron Power 20W or 30W Temperature range 150°C - 450°C Dimensions 190mm × 105mm × 22mm Weight 120g Part Number Table Description Part Number Kit, Solder and Repair, UK D01854 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 18 /05/12 V1.0
D01854 价格&库存
很抱歉,暂时无法提供与“D01854”相匹配的价格&库存,您可以联系我们找货
