D03145
D03145
    DURATOOL
    DURATOOL - D03145 - MULTIMETER WITH AUTOMOTIVE RANGES
D03145 数据手册
Model: D03145 Multimeter with Automotive Ranges 1 CONTENTS Page Number Description 3 What's Included? 3 Important Safety Information 3 General Specification 4 Electrical Specification 4 DC Voltage 4 AC Voltage 4 DC Current 4 AC Current 4 Temperature 5 Ohm 5 Dwell Angle 5 Tacho 5 AC & DC Voltage Measurement 5 AC & DC Current Measurement 6 Resistance Measurement 6 Temperature Measurement 6 Diode & Continuity Test 6 Transistor hFE Test (w/multifunction adaptor) 6 Measuring Dwell Angle 7 Testing Duty Cycle 7 Measuring Tacho 7 Battery & Fuse Replacement 7 Recycling Information 2 WHAT’S INCLUDED? • • One multimeter One pair of test leads • • One multifunction adaptor One user manual IMPORTANT SAFETY INFORMATION Please read these instructions carefully before use and retain for future reference. • • • • • • • • • • When using electrical appliances basic safety precautions should always be followed. Do not operate the meter if the test leads are damaged in any way. Damaged leads should be replaced. Function Range Input Terminals Maximum Input Do not exceed the input DCV 2~600V limits shown in the table VΩ COM 600V DC (right). ACV 2~600V To avoid damage to the OHM meter do not apply more VΩ COM 250V DC/AC Diode than 500V between any terminal and earth DCA 200mA mA COM 200mA DC/AC ground. ACA 200mA Disconnect the test leads DCA 10A from the circuit under 10A COM 10A DC/AC test before changing test ACA 10A ranges. Use caution when working above 60V DC or 25V AC rms, as such voltages pose a shock hazard. This meter is designed for indoor use only. Replace the battery as soon as the low battery indicator appears. Turn the meter off when it is not in use and remove the battery when not in use for a long period of time. Do not store the meter in a place of direct sunlight, high temperature or high humidity. GENERAL SPECIFICATION Display 3½ digit LCD Measurement Rate 2-3/sec Overrange Indication “1” will be displayed Polarity Indication Automatic negative Low Battery Indication “ + - ” displayed Overload Protection Full range Operating Temperature 0°C to 40°C, 0 to 75% RH Storage Temperature -10°C to 50°C, 0 to 75% RH Battery Type One 9V battery IEC 6F22, NEDA 1604 Dimensions 176 x 88 x 38mm (L x W x H) Weight 310g (including battery) 3 ELECTRICAL SPECIFICATION • Accuracy is given ± (% of reading + number of least significant digits) for one year, at 23°C ± 5°C RH
D03145 价格&库存
很抱歉,暂时无法提供与“D03145”相匹配的价格&库存,您可以联系我们找货
