DT000453
DT000453
    DURATOOL
    DURATOOL - DT000453 - Hex Driver Bit, Torx, Tamperproof, TT15 Tip, 25 mm Length
DT000453 数据手册
Torx Tamperproof Driver Bits Specifications Material : S2 Steel with Chrome Plating Dimension : 25mm × 6.35mm Driver Bit in Dark Green Label for Screw Holder Part Number Table Description Part Number Driver Bit, Torx, Tamperproof TT10, S2 Steel, 25mm × 6.35mm, Dark Green DT000452 Driver Bit, Torx, Tamperproof TT15, S2 Steel, 25mm × 6.35mm, Dark Green DT000453 Driver Bit, Torx, Tamperproof TT20, S2 Steel, 25mm × 6.35mm, Dark Green DT000454 Driver Bit, Torx, Tamperproof TT25, S2 Steel, 25mm × 6.35mm, Dark Green DT000455 Driver Bit, Torx, Tamperproof TT30, S2 Steel, 25mm × 6.35mm, Dark Green DT000456 Driver Bit, Torx, Tamperproof TT40, S2 Steel, 25mm × 6.35mm, Dark Green DT000457 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 06/04/18 V1.0
DT000453 价格&库存
很抱歉,暂时无法提供与“DT000453”相匹配的价格&库存,您可以联系我们找货
