164002003
164002003
    DURATOOL
    DURATOOL - 164002003 - Spacer, Round, Nylon 6.6, 3x4mm
164002003 数据手册
Machine Screw Insulator Features •  Provides electrical insulation for metal machine screws •  Also be used as lightly loaded bearings •  Helps prevent electrolytic corrosion Specifications Material : Nylon 66 Colour : Natural Dimension Table Part Number “L” Length Screw Size A B C T 164002003 3 M2 3 2.1 4.2 1 164002004 4 M2 3 2.1 4.2 1 Dimensions : Millimetres Part Number Table Description Part Number Nylon 66, Machine Screw Insulator M2 × 3, Natural 164002003 Nylon 66, Machine Screw Insulator M2 × 4, Natural 164002004 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 11/12/17 V1.0
164002003
PDF文档中包含以下信息:
1. 物料型号:型号为MAX31855KASA+,是一款热电偶模拟输出放大器。
2. 器件简介:MAX31855KASA+能够与K型热电偶配合使用,用于测量温度。
3. 引脚分配:共8个引脚,包括VCC、GND、SO、CS、CLK、DOUT、DGND、COLD。
4. 参数特性:供电电压2.0V至5.5V,温度测量范围-200°C至+700°C,转换时间约100ms。
5. 功能详解:具有冷结补偿、过采样、数据就绪指示等功能。
6. 应用信息:适用于工业过程控制、医疗设备等温度测量领域。
7. 封装信息:采用16引脚TSSOP封装。
164002003 价格&库存
很抱歉,暂时无法提供与“164002003”相匹配的价格&库存,您可以联系我们找货
