164006008
164006008
    DURATOOL
    DURATOOL - 164006008 - Spacer, Round, Nylon 6.6, 8x10mm
164006008 数据手册
Machine Screw Insulator Features •  Provides electrical insulation for metal machine screws •  Also be used as lightly loaded bearings •  Helps prevent electrolytic corrosion Specifications Material : Nylon 66 Colour : Natural Dimension Table Part Number “L” Length Screw Size A B C T 164003002 2 M3 4 3.1 6.2 1 164003003 3 M3 4 3.1 6.2 1 164003004 4 M3 4 3.1 6.2 1 164003005 5 M3 4 3.1 6.2 1 164003006 6 M3 4 3.1 6.2 1 164003007 7 M3 4 3.1 6.2 1 164003008 8 M3 4 3.1 6.2 1 164004003 3 M4 6 4.1 8.2 1.5 164004004 4 M4 6 4.1 8.2 1.5 164004005 5 M4 6 4.1 8.2 1.5 164004007 7 M4 6 4.1 8.2 1.5 164004009 9 M4 6 4.1 8.2 1.5 164005003 3 M5 7 5.1 10.2 2 164005004 4 M5 7 5.1 10.2 2 164005005 5 M5 7 5.1 10.2 2 164005007 7 M5 7 5.1 10.2 2 164005009 9 M5 7 5.1 10.2 2 164006004 4 M6 8 6.1 12.2 2 164006006 6 M6 8 6.1 12.2 2 164006008 8 M6 8 6.1 12.2 2 164006012 12 M6 8 6.1 12.2 2 164008004 4 M8 10 8.1 14.2 2.5 164008006 6 M8 10 8.1 14.2 2.5 164008008 8 M8 10 8.1 14.2 2.5 164008012 12 M8 10 8.1 14.2 2.5 All Tolerances (A,B,C,L&T=±0.26mm) www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 08/12/17 V1.0 Machine Screw Insulator Part Number Table Description Part Number Machine Screw Insulator M2 × 3 Nylon 66, Natural 164003002 Machine Screw Insulator M3 × 3 Nylon 66, Natural 164003003 Machine Screw Insulator M3 × 4 Nylon 66, Natural 164003004 Machine Screw Insulator M3 × 5 Nylon 66, Natural 164003005 Machine Screw Insulator M3 × 6 Nylon 66, Natural 164003006 Machine Screw Insulator M3 × 7 Nylon 66, Natural 164003007 Machine Screw Insulator M3 × 8 Nylon 66, Natural 164003008 Machine Screw Insulator M4 × 3 Nylon 66, Natural 164004003 Machine Screw Insulator M4 × 4 Nylon 66, Natural 164004004 Machine Screw Insulator M4 × 5 Nylon 66, Natural 164004005 Machine Screw Insulator M4 × 7 Nylon 66, Natural 164004007 Machine Screw Insulator M4 × 9 Nylon 66, Natural 164004009 Machine Screw Insulator M5 × 3 Nylon 66, Natural 164005003 Machine Screw Insulator M5 × 4 Nylon 66, Natural 164005004 Machine Screw Insulator M5 × 5 Nylon 66, Natural 164005005 Machine Screw Insulator M5 × 7 Nylon 66, Natural 164005007 Machine Screw Insulator M5 × 9 Nylon 66, Natural 164005009 Machine Screw Insulator M6 × 4 Nylon 66, Natural 164006004 Machine Screw Insulator M6 × 6 Nylon 66, Natural 164006006 Machine Screw Insulator M6 × 8 Nylon 66, Natural 164006008 Machine Screw Insulator M6 × 12 Nylon 66, Natural 164006012 Machine Screw Insulator M8 × 4 Nylon 66, Natural 164008004 Machine Screw Insulator M8 × 6 Nylon 66, Natural 164008006 Machine Screw Insulator M8 × 8 Nylon 66, Natural 164008008 Machine Screw Insulator M8 × 12 Nylon 66, Natural 164008012 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 08/12/17 V1.0
164006008
物料型号:文档列出了多种尺寸和螺丝尺寸的Machine Screw Insulator,例如164003002、164003003等,它们都使用Nylon 66材料制成,颜色为自然色。
器件简介:Machine Screw Insulator提供金属机械螺丝的电气绝缘,并且可以用作轻载轴承,有助于防止电化学腐蚀。
引脚分配:文档中没有明确提到“引脚分配”,因为这不是电子元件,而是一种绝缘材料。
参数特性:材料为Nylon 66,颜色为自然色,尺寸表详细列出了不同型号的尺寸参数,包括长度("L")、螺丝尺寸、A、B、C和T尺寸,所有尺寸的公差为±0.26mm。
功能详解:文档没有提供“功能详解”,但根据简介,这些绝缘体可以提供电气绝缘,用作轻载轴承,并防止电化学腐蚀。
应用信息:文档没有明确提供“应用信息”,但可以推断这些绝缘体适用于需要电气绝缘和轻载轴承的场合。
封装信息:文档提供了详细的尺寸表,可以视为封装信息,列出了不同型号的详细尺寸。
164006008 价格&库存
很抱歉,暂时无法提供与“164006008”相匹配的价格&库存,您可以联系我们找货
