D00727
D00727
    DURATOOL
D00727 数据手册
Dome Plugs This nylon dome plug is ideal for covering unwanted openings, with its convex, matt finished head tapering to a thin edge for an excellent appearance. As the dome plugs are manufactured from nylon 6,6 they offer a good resistance to most solvents, aromatic hydrocarbons, dilute alkalis, detergents, oils, greases, and fats. They also other a limited resistance to dilute acids and offer a short term working temperature between -40 and 100°C. The dome plug is quick and easy to install. Fingertip pressure will lock the dome plug firmly into panels to provide a neat finish. The plug head height is only 1.6mm. UL/CSA Description DP-187 DP-250 DP-312 DP-375 DP-437 DP-500 DP-562 DP-625 MDP-16 DP-687 DP-750 MDP-20 DP-812 DP-875 MDP-25 DP-1000 DP-1093 Mounting Hole Diameter (mm) 4.8 6.4 8.0 9.5 11.0 12.7 14.3 15.9 16.0 17.5 19.0 20.0 20.6 22.2 25.0 25.4 27.8 - 28.6 Max. Chassis Thickness (mm) 1.6 1.6 1.6 3.2 3.2 3.2 3.2 3.2 2.5 3.2 3.2 2.5 3.2 3.2 2.5 3.2 3.2 Plug Head Diameter (mm) 6.4 7.9 9.5 11.9 13.5 14.7 16.7 18.2 18.5 19.8 23.4 22.6 22.6 25.8 29.8 30.6 30.9 Overall Height (mm) 5.9 7.9 7.9 10.3 10.3 10.3 10.3 10.3 10.3 10.3 10.3 10.3 10.3 11.5 11.5 11.5 11.5 492107 Price Per Pack UL/CSA Decsription Pack Qty DP-187 DP-250 DP-312 DP-375 DP-437 DP-500 DP-562 DP-625 MDP-16 DP-687 DP-750 MDP-20 DP-812 DP-875 MDP-25 DP-1000 DP-1093 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 Order Code 151-4449● 151-4450● 151-4451● 151-4452● 151-4454● 151-4455● 151-4456● 151-4457● 151-4458● 151-4459● 151-4460● 151-4461● 151-4462● 151-4463● 151-4464● 151-4466● 151-4467●
D00727 价格&库存
很抱歉,暂时无法提供与“D00727”相匹配的价格&库存,您可以联系我们找货
