D01349
D01349
    DURATOOL
D01349 数据手册
Circuit Board Spacers SPLSN Series PART NUMBER 1645287 1645288 1645289 1645290 1645291 1645292 1645293 1645294 1645295 1645296 1645297 1645299 A B 4.9 6.2 9.4 11.0 12.5 15.7 18.9 22.0 25.1 28.3 31.5 34.6 7.1 8.4 11.6 13.2 14.7 17.9 21.1 24.2 27.3 30.5 33.7 36.8  Material: Nylon 66 Flammability: UL94V-2 Colour: Natural   Dimensions Mounting Holes ø PCB Chassis 4 4 4 4 4 4 4 4 4 4 4 4 4.8 4.8 4.8 4.8 4.8 4.8 4.8 4.8 4.8 4.8 4.8 4.8 Applicable Thickness PCB Chassis 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.8~1.6 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 Firmly and accurately maintains a constant distance between the chassis and PC board Quick and easy to install Easy to remove from the PC board RoHS Directive 2002/95/EC compliant RoHS  The mid-section design of 1645287 is different Material Properties Values measured at 23°C @ 50% RH Mechanical/Physical Properties Units Value Density Water Absorption Tensile Strength at Break Elongation at Yield Tensile Modulus g/cm3 % MPa % GPa 1.14 2.8 50 30 1.50 Electrical Properties Units Value Electrical Resistivity Surface Resistivity Electrical Strength ohm-m ohm MV/m 3.00e+13 3.00e+14 26 Thermal Properties Units Value Melting Point Short Term Minimum Working Temperature Short Term Maximum Working Temperature Flammability °C °C °C UL94 263 -40 100 V2 Above information is for guidance only and should not be used to establish specifications or as the basis of a design Circuit Board Spacers SPD Series PART NUMBER 1645300 1645302 1645303 1645305 1645306 1645307 1645308 1645309 A B 4.6 5.9 9.1 10.7 12.2 15.4 18.6 21.7 8.9 10.2 13.4 15.0 16.5 19.7 22.9 26.0 Material: Nylon 66 Flammability: UL94V-2 Colour: Natural   Dimensions Mounting Holes ø PCB Chassis 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 Applicable Thickness PCB Chassis 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 Fixes the chassis and PC board at a constant distance between each other Uses Ø4 mounting holes on both the chassis and PC board RoHS Directive 2002/95/EC compliant RoHS  Material Properties Values measured at 23°C @ 50% RH Mechanical/Physical Properties Units Value Density Water Absorption Tensile Strength at Break Elongation at Yield Tensile Modulus g/cm3 % MPa % GPa 1.14 2.8 50 30 1.50 Electrical Properties Units Value Electrical Resistivity Surface Resistivity Electrical Strength ohm-m ohm MV/m 3.00e+13 3.00e+14 26 Thermal Properties Units Value Melting Point Short Term Minimum Working Temperature Short Term Maximum Working Temperature Flammability °C °C °C UL94 263 -40 100 V2 Above information is for guidance only and should not be used to establish specifications or as the basis of a design Circuit Board Spacers RSPLS Series PART NUMBER 1645310 1645311 1645312 1645313 1645314 1645315 1645317 1645318 1645319 1645320 A øD 5.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 6.2 12.8 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 4.6 4.6  Material: Nylon 66 Flammability: UL94V-2 Colour: Natural  Dimensions Mounting Holes ø PCB Chassis 4.0 5.5 4.0 5.5 4.0 5.5 4.0 5.5 4.0 5.5 4.0 5.5 4.0 5.5 4.0 5.5 3.2 4.8 3.2 4.8 Applicable Thickness PCB Chassis 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 1.6 0.5~1.0 Inserts into the underside of the chassis Protrusion below the chassis is less than 1.7, making this series ideal when space is limited RoHS Directive 2002/95/EC compliant RoHS  Figures in boxes are the dimensions for 1645319 and 1645320 The mid-section designs of 1645310 and 1645311 are different Material Properties Values measured at 23°C @ 50% RH Mechanical/Physical Properties Units Value Density Water Absorption Tensile Strength at Break Elongation at Yield Tensile Modulus g/cm3 % MPa % GPa 1.14 2.8 50 30 1.50 Electrical Properties Units Value Electrical Resistivity Surface Resistivity Electrical Strength ohm-m ohm MV/m 3.00e+13 3.00e+14 26 Thermal Properties Units Value Melting Point Short Term Minimum Working Temperature Short Term Maximum Working Temperature Flammability °C °C °C UL94 263 -40 100 V2 Above information is for guidance only and should not be used to establish specifications or as the basis of a design Circuit Board Spacers SHCBS Series PART NUMBER 1645321 1645322 1645323 1645324 A B 7.9 9.5 12.6 15.8 10.3 11.9 15.0 18.2  Material: Nylon 66 Flammability: UL94V-2 Colour: Natural   Dimensions Mounting Holes ø Applicable Thickness PCB Chassis PCB Chassis 4.0 4.0 4.0 4.0 4.8 4.8 4.8 4.8 1.6 1.6 1.6 1.6 0.5~2.0 0.5~2.0 0.5~2.0 0.5~2.0 Easily installed and removed, making inspection and maintenance of PC boards easier A hinging action can be achieved when used together with the SRF series of spacers Designed to accompany SRF series when creating a lifting hinge action with the PCB RoHS Directive 2002/95/EC compliant RoHS  Material Properties Values measured at 23°C @ 50% RH Mechanical/Physical Properties Units Value Density Water Absorption Tensile Strength at Break Elongation at Yield Tensile Modulus g/cm3 % MPa % GPa 1.14 2.8 50 30 1.50 Electrical Properties Units Value Electrical Resistivity Surface Resistivity Electrical Strength ohm-m ohm MV/m 3.00e+13 3.00e+14 26 Thermal Properties Units Value Melting Point Short Term Minimum Working Temperature Short Term Maximum Working Temperature Flammability °C °C °C UL94 263 -40 100 V2 Above information is for guidance only and should not be used to establish specifications or as the basis of a design
D01349 价格&库存
很抱歉,暂时无法提供与“D01349”相匹配的价格&库存,您可以联系我们找货
