D02158
D02158
    DURATOOL
D02158 数据手册
Rotary Tool Set – 208 Pieces Kit Contents Content Qty Content 20pcs smaller sanding band 6.35 × 12.7mm, grain 80 10 20pcs bigger sanding band 12.7 × 12.7mm, grain 80 10 1pc cloth wheel 25.4 × 3.2mm 1 1pc rubber emery wheel 22.2 × 4mm 1 4pcs smaller felt wheel 12.7 × 9.5mm 4 1pc bigger felt wheel 25.4 × 6.35mm 1 1pc polished HSS twist drills Dia. 3.2mm 1 1pc polished HSS twist drills Dia. 2.4mm 1 1pc polished HSS twist drills Dia. 1.6mm 1 1pc felt wheel point 9.5 × 19mm 1 1pc smaller sanding shank 6.35 × 12.7mm 1 1pc bigger sanding shank 12.7 × 12.7mm 1 1pc diamond cutter 2.4 × 9.5mm 1 1pc diamond cutter Dia. 4mm 1 1pc diamond cutter Dia. 2mm 1 1pc diamond cutter Dia. 3.2mm 1 1pc diamond cutter 3.2 × 6.4mm 1 1pc diamond cutter 3.2 × 6.4mm 1 1pc HSS cutter Dia. 9.5mm 1 1pc Nylon brush axial 5 × 43mm 1 1pc Nylon brush axial 12.7 × 43mm 1 1pc Nylon brush axial 21 × 43mm 1 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 15/03/19 V1.0 Rotary Tool Set – 208 Pieces Content Qty Content 1pc brass brush axial 5 × 43mm 1 1pc brass brush axial 12.7 × 43mm 1 1pc brass brush axial 21 × 43mm 1 1pc stainless steel brush 5 × 43mm 1 1pc stainless steel brush 12.7 × 43mm 1 1pc stainless steel brush 21 × 43mm 1 1pc polish compound 21g 1 46pcs cut off wheel regular Dia. 24 × 04mm 46 30pcs cut off wheel heavy duty Dia. 24 × 0.8mm 30 15pcs sanding disc Dia. 20.5mm grain 220 15 15pcs sanding disc Dia. 20.5mm grain 180 15 14pcs sanding disc Dia. 20.5mm grain 240 14 2pcs chrome plated collect Dia. 3.2mm 2 1pc chrome plated collect Dia. 2.4mm 1 1pc chrome plated collect Dia. 1.6mm 1 1pc mandrel for felt wheel Dia. 3.17 × 38mm 1 1pc mandrel for cloth wheel M2.4mm 1 2pcs mandrel for cut off wheel M1.6mm 2 5pcs cut off wheel fibre glass 32 × 1.2mm 5 1pc dressing stone SI carbide 9.5 × 9.5 × 25.4mm 1 1pc wrench 9.5mm 1 1pc flap wheel 32 × 9.5mm 1 2pcs aluminium oxide grinding wheel with shank 15.8 × 9.6 mm 2 2pcs aluminium oxide grinding wheel with shank 9.5 × 12.7mm 2 2pcs aluminium oxide grinding wheel with shank 9.5 × 20mm 2 6pcs aluminium oxide grinding wheel 20 × 3.6mm 6 2pcs silicon carbide grinding wheel with shank 20 × 4mm 2 2pcs silicon carbide grinding wheel with shank 10.3 × 4mm 2 6pcs silicon carbide grinding wheel 20 × 3.6mm 6 Part Number Table Description Part Number Rotary Tool Set – 208 Pieces D02158 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 15/03/19 V1.0
D02158 价格&库存
很抱歉,暂时无法提供与“D02158”相匹配的价格&库存,您可以联系我们找货
