Hexagon Nut And Screw Head Covers
PART NUMBER
White
Nominal
Thread Size
Across Flats
Hexagon
H
Black
*1639575
*1639576
*1639577
1639578
1639579
1639580
*1639581
*1639582
*1639583
1639585
1639586
1639587
M4
M5
M6
M8
M10
M12
6.9
7.9
9.8
13.0
16.7
18.7
8.7
10.7
13.0
15.0
19.5
21.5
Material: Low Density Polyethylene
RoHS Directive 2002/95/EC compliant
RoHS
Protects and gives a neat finish to exposed metal hexagon nuts and screw heads
Quick and simple to install
This part has a circular external form and a hexagonal internal form and is suitable for Hexagon Head screws and nuts. Parts marked
* will also fit the appropriate size Metric Cheese Head Screw (Chapter 6)
Material Properties
Mechanical/Physical Properties
Units
Value
Density
Water Absorption
Tensile Strength, Yield
Elongation at Yield
Tensile Modulus
g/cm3
MPa
GPa
0.924
0.01
11.0
14.5
0.260
Electrical Properties
Units
Value
Electrical Resistivity
Surface Resistivity
Dielectric Constant (1 MHz)
ohm-cm
ohm
≥1.00e+15
1.00e+14
2.30
Thermal Properties
Units
Value
Melting Point
Short Term Minimum Working Temperature
Short Term Maximum Working Temperature
Flammability
Oxygen Index
°C
°C
°C
UL94
111
-40
55
HB
17.0
Above information is for guidance only and should not be used to establish specifications or as the basis of a design
Hinged Screw Covers
PART NUMBER
Black
White
Red
Green
1639588
1639589
1639590
1639591
1639592
1639593
1639594
1639595
1639597
1639598
1639599
1639600
Material: Polypropylene
Screw Size
A
B
M3/M4 & N°4
M4/M5 & N°8/N°10
M6 & 1/4"
11.5
13.7
17.4
5.0
5.5
6.5
All-in-one base and cover
Cap snaps into base to give a neat and decorative finish
Available in matt finish only
RoHS
Material Properties
Units
3
Value
Density
Hardness
Elongation at Yield
Flexural Modulus
g/cm
Shore D
MPa
GPa
0.9
71
35.9
490
1.39
Thermal Properties
Units
Value
Deflection Temperature at 0.45MPa
Vicat Softening Temperature
°C
°C
104
150
Pop-On Screw Covers
PART NUMBER
Black
White
Red
Green
1639601
1639603
1639604
1639605
1639606
1639607
1639608
1639609
1639610
1639611
1639612
1639613
Screw Size
A
B
M3/M4
M4/M5
M6
12.7
16.0
17.8
5.1
6.5
6.6
Can also be used with No 4, 6, 8, 10 and s - 20 screws
RoHS
Allow approximately 0.50 extra for
assembled height
These parts must be used with Pop-On
Screw Cover Bases - see below
Pop-On Screw Cover Bases
PART NUMBER
To Fit Pop-on Screw
Covers
Screw Size
A
B
C
D
1639615
1639616
1639617
1639618
1639619
1639620
1639621
1639622
1639601 to 1639611
1639601 to 1639611
1639601 to 1639611
1639603 to 1639612
1639603 to 1639612
1639603 to 1639612
1639604 to 1639613
1639604 to 1639613
M3 & No4 Pan
M3.5 & No6 Pan
M3/M4 & No4/No8 CSK
M4 & No8 PAN
M5 & No10 PAN
M4/M5 & No8/No10 CSK
M6 & 1/4" PAN
M6 & 1/4" CSK
2.9
2.9
2.9
3.2
3.2
3.2
3.2
3.3
10.5
10.5
10.5
12.7
12.8
12.8
15.7
15.7
3.0
3.8
3.8
4.5
5.0
5.0
6.2
6.2
7.0
7.0
9.3
9.3
12.4
Colour: Natural
compliant
RoHS
Pop-on screw covers and bases may be used with:- flat head nails, countersunk screws, self
tapping screws, rivets, drive screws, machine screws, washer faced screws and other types
of fasteners
Cover locks firmly onto base to provide a neat and decorative finish
Material Properties
Units
Value
Density
Hardness
Elongation at Yield
Flexural Modulus
g/cm3
Shore D
MPa
GPa
0.9
71
35.9
490
1.39
Thermal Properties
Units
Value
°C
°C
104
150
Metric Knurled Thumb Nuts
PART
NUMBER
Thread
Size
A
B
H
L
Form
1639623
1639624
1639625
1639627
1639628
1639629
1639630
M3 x .5
M4 x .7
M5 x .8
M6 x 1.0
M4 x .7
M5 x .8
M6 x 1.0
12.0
12.0
16.0
16.0
16.0
16.0
16.0
7.0
7.0
9.5
9.5
9.5
9.5
9.5
7.0
7.0
8.0
8.0
8.0
8.0
8.0
3.5
3.5
4.5
4.5
4.5
4.5
4.5
A
A
A
A
B
B
B
PART
NUMBER
Thread
Size
A
B
H
L
Form
1639631
1639632
1639633
1639634
1639635
1639636
M4 x .7
M5 x .8
M6 x 1.0
M4 x .7
M5 x .8
M6 x 1.0
16.0
16.0
16.0
16.0
16.0
16.0
10.0
10.0
10.0
10.0
10.0
10.0
6.0
6.0
6.0
6.0
6.0
6.0
4.5
4.5
4.5
4.5
4.5
4.5
C
C
C
D
D
D
Material: Nylon 66
Colour: White
compliant
RoHS
Thread Size
Suggested Max. Tightening Torque
(Nm) for Nylon 6,6 screws as per DIN3481X
M3
M4
M5
M6
0.10
0.25
0.50
0.80
N/A = Test data not available
1Nm = 8.851lbf-in
Material Properties
Values measured at 23°C @ 50% RH
Units
Value
Density
Water Absorption
Tensile Strength at Break
Elongation at Yield
Tensile Modulus
g/cm3
MPa
GPa
1.14
1.3
55
30
1.50
Units
Value
Surface Resistivity
Dielectric Strength
ohm-cm
ohm
kV/mm
≥1.00e+14
0.10e+14
26
Thermal Properties
Units
Value
Melting Point
Flammability
Oxygen Index
°C
°C
°C
UL94
263
-40
110
V2
26.5
很抱歉,暂时无法提供与“D01296”相匹配的价格&库存,您可以联系我们找货
