D03354
D03354
    DURATOOL
    DURATOOL - D03354 - Gas Torch, 20 min, 1300 Deg C, 51 g, 27 x 60 x 105 mm
D03354 数据手册
Mini Gas Blow Torches D03353 Features Specification for D03353 •  •  •  •  •  •  Temperature Max Run Time Weight External Height External Width External Depth Piezo auto ignition Safety lock Fuelled by a standard cigarette lighter inside the handle (not supplied) Supplied with stand Can also be used in the kitchen for culinary purposes Requires butane gas (not supplied) : 1300°C : 20min : 68g : 115mm : 72mm : 20mm D03354 Features Specification for D03354 •  •  •  •  •  •  Temperature Max Run Time Weight External Height External Width External Depth Piezo auto ignition Safety lock Continuous flame lock Stand built into the base Can also be used in the kitchen for culinary purposes Requires butane gas (not supplied) : 1300°C : 20min : 51g : 105mm : 60mm : 27mm Part Number Table Description Part Number Mini Gas Blow Torch, 1300°C, 20min Run Time, 68g D03353 Mini Gas Blow Torch, 1300°C, 20min Run Time, 51g D03354 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 08/10/20 V1.0
D03354 价格&库存
很抱歉,暂时无法提供与“D03354”相匹配的价格&库存,您可以联系我们找货
