GPL-500
GPL-500
    DURATOOL
    DURATOOL - GPL-500 - Five Piece Plier Set
GPL-500 数据手册
Date • 6" DIAGONAL CUTTING PLIER • Material: HRC-45 • Blade Material: Nickel-Iron Alloy • 6" LONG NOSE PLIER • Material: HRC-45 • Blade Material: Nickel-Iron Alloy 16.4 cm 5.5 cm • COMBINATION PLIER 7" (180mm) • Material: HRC-45 • Blade Material: Nickel-Iron Alloy 16 cm 5 cm Rev. • 8" SLIP JOINT PLIERS • Material: HRC-45 • Blade Material: Nickel-Iron Alloy 18 cm 5.3 cm 20.3 cm GOLDSUN ELECTRONICS CO., LTD. DRAWN: Johnson VERIFY PEOPLE: 20.3 cm 5 cm ITEM NO. A4 DRAWING NO. • 8" WATER PUMP PLIER • Material: HRC-45 • Blade Material: Nickel-Iron Alloy 5 cm MATERIAL DCC. NO. Description 26W6263 Description Chesley MFG NO. GPL-500 Rev. 5 Pieces Plier Set UNIT: mm SCALE: CAS No: SHEET 1 OF 1 ERN No: 1
GPL-500 价格&库存
很抱歉,暂时无法提供与“GPL-500”相匹配的价格&库存,您可以联系我们找货
