942-0070
942-0070
    DURATOOL
942-0070 数据手册
Hydraulic Series Features: • A complete easy to use System enabling a wide variety of hole configurations to conjunction with the Hydraulic kit 940-0000 • Suitable for sheet steel, stainless, non-ferrous metal and plastics. Ideal for switchgear manufacturers, electricians, Plumbers and handi-crafters • Heat treated steel punches and dies manufactured to close tolerances will punch burr free holes up to 3mm thick in steel and 4mm thick in aluminium Punches and dies are made from case hardened steel to give reduce wear and give long life Special sizes available on request Specification Table Description Size Pilot hole Bolt size Thrust Bearing Part Number Circular Hydraulic Hole Cutter, 20mm 20 12 10 NA 942-0010 Round Hydraulic Hole Cutter, 22.5mm 22.5 12 10 NA 942-0020 Circular Hydraulic Hole Cutter, 25mm 25 12 10 NA 942-0030 27.5 12 10 NA 942-0040 Circular Hydraulic Hole Cutter, 30mm 30 12 10 NA 942-0050 Circular Hydraulic Hole Cutter, 35mm 35 14.5 12 NA 942-0060 Circular Hydraulic Hole Cutter, 76mm 76.2 20 24 NA 942-0070 Circular Hydraulic Hole Cutter, 116mm 116 25 16 NA 942-0080 Circular Hydraulic Hole Cutter, 27.5mm www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 15/11/11 V1.1 Hydraulic Series Specification Table Description Size Pilot hole Bolt size Thrust Bearing Part Number Square Hydraulic Hole Cutter, 45mm 45 × 45 20 16 NA 943-0010 Square Hydraulic Hole Cutter, 68mm 68 × 68 20 16 NA 943-0020 Square Hydraulic Hole Cutter, 92mm 92 × 92 35 M24 NA 943-0030 Hydraulic Power Pack Hydraulic Pump/Ram, Power Pack 940-0000 The power pack, complete with pump cylinder and 1.8metre of high pressure hose exerts a force capable of cutting larger holes in thicker materials. Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2011. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 15/11/11 V1.1
942-0070 价格&库存
很抱歉,暂时无法提供与“942-0070”相匹配的价格&库存,您可以联系我们找货
