D03343
D03343
    DURATOOL
    DURATOOL - D03343 - Lead Free Solder Wire, 1.2mm, 12.5g, 1.8m
D03343 数据手册
Lead Free Solder Wire Features •  •  •  •  Excellent solder joint reliability. Superior joint strength. Excellent thermal & Mechanical fatigue resistance. Low cleaning required after solder joint. Specifications Characteristics Appearance Standard Bright and shiny surface finishes Alloy Sn/ Cu 0.7 JIS-Z-3282 Melting Point 227°C to 228°C DSC Flux Content 3 ±1% JIS-Z-3283 Under 0.5% JIS-Z-3197 Halide Content Gravity 7.3 Spread Ability Diameters (Tolerances) Storage, Handling and Shelf Life >75% JIS-Z-3197 0.3mm to 0.6mm ±0.05mm, 0.8mm to 3mm ±0.1mm JIS-Z-3283 Storage must be in a dry, non-corrosive and shine environment. Avoids the oxidant, the acid and the hydrogen peroxide. Shelf life is 2 years from date of manufacture. Physical Properties & Reliability Data No Test Item Test Result Test Method 1 Copper Mirror Test PASS IPC-TM-650, 2.3.32 2 Copper Plate Corrosion PASS 3 S.I.R Test PASS 1x10 up IPC-TM-650, 2.6.3.3 4 Electro Migration Test PASS 1x1010 up IPC-TM-650, 2.6.14.1 JIS-Z-3197, 6.6.1 10 Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 23/10/19 V1.0 Lead Free Solder Wire Alloy Composition Sn Cu Ag Ni Bi Zn Ai Sb Fe As Cd Pb In Au Rem. 0.5~0.9 0.1 MAX 0~0.01 0.1 MAX 0.001 MAX 0.001 MAX 0.05 MAX 0.02 MAX 0.03 MAX 0.002 MAX 0.05 MAX 0.1 MAX 0.05 MAX Part Number Table Description Part Number Solder Wire, Sn 99.3/Cu 0.7, 0.7mm Dia, 100G D01685 Solder Wire, Sn 99.3/Cu 0.7, 0.7mm Dia, 500G D01686 Solder Wire, Sn 99.3/Cu 0.7, 1.2mm Dia, 100G D01687 Solder Wire, Sn 99.3/Cu 0.7, 1.2mm Dia, 500G D01688 Solder Wire, Sn 99.3/Cu 0.7, 0.7mm Dia, 50G D03341 Solder Wire, Sn 99.3/Cu 0.7, 0.7mm Dia, 250G D03342 Solder Wire, Sn 99.3/Cu 0.7, 1.2mm Dia, 12.5G D03343 Solder Wire, Sn 99.3/Cu 0.7, 1.2mm Dia, 50G D03344 Solder Wire, Sn 99.3/Cu 0.7, 1.2mm Dia, 250G D03345 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 23/10/19 V1.0
D03343 价格&库存
很抱歉,暂时无法提供与“D03343”相匹配的价格&库存,您可以联系我们找货
