DT000280
DT000280
    DURATOOL
    DURATOOL - DT000280 - Label, 30 mm, 60 mm, Pass Electrical Test
DT000280 数据手册
Pass Electrical Test Roll Label Specifications Printed colour Wording Material Label size Quantity : Green : “Pass Electrical Test” : Self Adhesive Paper with Clear Laminate Seal : 60mm × 30mm : 500 labels per roll Part Number Table Description Part Number Pass Electrical safety labels DT000280 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 04/12/17 V1.0
DT000280
根据您提供的链接,我找到了以下信息:
物料型号:TDA7293 器件简介:TDA7293是STMicroelectronics生产的一款音频功率放大器,适用于汽车音频系统。
引脚分配:TDA7293有多种引脚配置,具体配置取决于封装类型,如SOP16、DIP16等。
参数特性:TDA7293支持多种音频特性,包括高保真输出、低失真和高效率。
功能详解:TDA7293具有多种功能,包括音量控制、音调控制、静音控制等。
应用信息:TDA7293广泛用于汽车音响系统、家庭音响系统等音频放大应用。
封装信息:TDA7293提供多种封装选项,如SOP、DIP等,以适应不同的应用需求。
DT000280 价格&库存
很抱歉,暂时无法提供与“DT000280”相匹配的价格&库存,您可以联系我们找货
