DT000473
DT000473
    DURATOOL
    DURATOOL - DT000473 - Fume Extractor, Bench, Fan, 23 W, 1.2 m³/min Air Volume, EU Plug
DT000473 数据手册
Dual Function Bench Fan and Solder Smoke Absorber Product Overview •  •  •  •  Dual function: It can be used as a bench fan or as a solder smoke absorber. The fan is designed to sit on a desktop or can be hung from a support beam. 1 carbon fibre filter is included. Low noise and long life service fan. Specifications Power Absorption Capacity Airflow volume Plug : 23W : 0.2-1M³/minute (Max) : 0.2-1.2M³/minute (Max) : EU Operation •  Position the fan as required. •  If using the bench fan function, face the front side towards you. •  If using the smoke absorber function, make sure the carbon filter has been inserted, and face the reverse side towards the solder smoke. •  Plug the fan into a mains power outlet. •  Activate the on/off Switch. •  To change the fan speed from 1 to 10, adjust the speed control Diagram Part Number Table Description Part Number Dual Function Bench Fan and Solder Smoke Absorber DT000473 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 12/03/19 V1.0
DT000473 价格&库存
很抱歉,暂时无法提供与“DT000473”相匹配的价格&库存,您可以联系我们找货
