D00289
D00289
    DURATOOL
D00289 数据手册
69 Piece Tool Kit A 69 piece tool kit ideal for the household, supplied in a handy foldup blow moulded carry case. Contents: Ì Ì Ì Ì Ì Ì Ì Ì Ì Ì Ì Ì Ì Ì Junior hacksaw 150mm mini level 125mm x 250mm roofing square 3m measuring tape with rubber cover 16oz tubular hammer with rubber grip Ratchet screwdriver 60mm bit holder 200mm adjustable wrench with dipped handle 175mm (7") carpenter pencil 150mm (6") stainless ruler Trim knife with soft comfortable handle 2 x electric clips 150mm (6") combination pliers 150mm (6") long nose pliers Ì 150mm (6") side cutting pliers Ì 4 x screwdrivers with cushion grip: - Slotted: 5 x 75mm, 6 x 100mm - Phillips: PH1 x 75mm, PH2 x 100mm Ì 9 x hex keys: 1.5, 2, 2.5, 3, 4, 5, 6, 8, 10mm Ì 40 x 25mm bits: - Slotted: 3, 3, 4, 4, 5, 5, 6, 6, 7, 7mm - Phillips: PH0, PH1, PH2, PH2, PH2, PH3 - Pozidriv: PZ0, PZ1, PZ2, PZ2, PZ2, PZ3 - Torx: T10, T15, T20, T25, T27, T30, T40 - Square: S0, S1, S2, S2, S3 - Hex: 3, 4, 5, 6, 7mm 477636.452483 Price Each Order Code 136-1386
D00289 价格&库存
很抱歉,暂时无法提供与“D00289”相匹配的价格&库存,您可以联系我们找货
