D01841
D01841
    DURATOOL
    DURATOOL - D01841 - Hot Air SMD Rework Station, 480°C, 240V, UK Plug
D01841 数据手册
D01841 – Hot Air SMD Rework Station with LCD Display • • • • A wide range of adjustment of the air flow rate and temperature permits soldering and desoldering of SMDs Closed loop control of temperature Automatic cooling mode – Protects the heating element and handle when the power switch is turned off Supplied with 4 nozzles Contents: Rework station with holder, hand piece and 1m tube, 4 x nozzles (Ø2.5, 4.4mm 10x10, 15x15mm QFP), mains lead and user instructions Technical Data Air Pump: Capacity: Hot Air Temperature: Sensor Type: Hot Air Shaft Dia.: Dimensions (HxWxD): Supply Voltage: Spares / Accessories D01701 Replacement Heater Element Diaphragm Pump 24 Litres/Minute 480 °C 150 - 500ºC K Thermocouple 21.5mm 150x160x225mm 220 – 240V
D01841 价格&库存
很抱歉,暂时无法提供与“D01841”相匹配的价格&库存,您可以联系我们找货
