DT000418
DT000418
    DURATOOL
    DURATOOL - DT000418 - Machine Screw, M6, 12 mm, Metal, Black Oxide, Pan Head Pozidriv - Machine Scre...
DT000418 数据手册
Pan Head Pozidriv Screw Specifications Head Type Finish : Pan Head Pozidriv : Black Oxide Diagram Part Number Table Description Pan Head Pozidriv Screw Thread Length size (L) Pack of Qty. Part Number Description Thread Length size (L) Pack of Qty. Part Number M2 6mm DT000366 M3.5 16mm DT000390 M2 8mm DT000367 M3.5 20mm DT000391 M2 10mm DT000368 M3.5 25mm DT000392 M2 12mm DT000369 M4 5mm DT000393 M2.5 6mm DT000370 M4 6mm DT000394 M2.5 8mm DT000371 M4 8mm DT000395 M2.5 10mm DT000372 M4 10mm DT000396 M2.5 12mm DT000373 M4 12mm DT000397 M2.5 16mm DT000374 M4 16mm DT000398 M2.5 20mm DT000375 M4 20mm DT000399 M3 4mm DT000376 M4 25mm DT000400 M3 5mm DT000377 M4 30mm M3 6mm M4 35mm 50 DT000378 Pan Head Pozidriv Screw 50 DT000401 DT000402 M3 8mm DT000379 M4 40mm DT000403 M3 10mm DT000380 M4 50mm DT000404 M3 12mm DT000381 M5 6mm DT000405 M3 16mm DT000382 M5 8mm DT000406 M3 20mm DT000383 M5 10mm DT000407 M3 25mm DT000384 M5 12mm DT000408 M3 30mm DT000385 M5 16mm DT000409 M3 40mm DT000386 M5 20mm DT000410 M3.5 8mm DT000387 M5 25mm DT000411 M3.5 10mm DT000388 M5 30mm DT000412 M3.5 12mm DT000389 M5 35mm DT000413 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 24/01/18 V1.0 Pan Head Pozidriv Screw Description Pan Head Pozidriv Screw Thread Length size (L) Pack of Qty. Part Number Description Thread Length size (L) Pack of Qty. Part Number M5 40mm DT000414 M6 35mm DT000423 M5 50mm DT000415 M6 40mm DT000424 M5 60mm DT000416 M6 45mm DT000425 M6 10mm M6 50mm M6 12mm M6 60mm M6 16mm DT000419 M8 20mm DT000428 M6 20mm DT000420 M8 25mm DT000429 M6 25mm DT000421 M8 30mm DT000430 M6 30mm DT000422 M8 50mm DT000431 DT000417 50 DT000418 Pan Head Pozidriv Screw DT000426 50 DT000427 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 24/01/18 V1.0
DT000418
1. 物料型号:文档列出了不同尺寸和长度的螺丝型号,包括M2至M8的不同螺纹尺寸,以及4mm至50mm不等的长度规格。
2. 器件简介:文档没有提供具体的器件简介,但根据标题可以推断,这些是用于各种工业和制造应用的圆头十字槽螺丝。
3. 引脚分配:文档中没有提及引脚分配,因为这是关于螺丝的文档,而不是电子元件。
4. 参数特性:文档提供了螺丝的螺纹尺寸、长度和包装数量等参数特性
5. 功能详解:文档没有提供详细的功能解释,但圆头十字槽螺丝通常具有自锁功能,适用于需要防止螺丝松动的应用。
6. 应用信息:文档没有明确列出具体的应用信息,但圆头十字槽螺丝广泛应用于各种工业和制造领域。
7. 封装信息:文档中没有提及封装信息,因为螺丝通常不涉及电子封装。
DT000418 价格&库存
很抱歉,暂时无法提供与“DT000418”相匹配的价格&库存,您可以联系我们找货
