AH-010
AH-010
    DURATOOL
    DURATOOL - AH-010 - Soldering Tip, Conical, Duratool D03359 Gas Soldering Iron
AH-010 数据手册
Gas Soldering Iron Kit and Tips D03359 Features •  P  owered by butane gas (not supplied), can also be used as a torch or hotblower •  Piezo auto ignition •  Adjustable gas flow •  On/Off and safety switches •  Supplied with cap, coil of solder and 4x bits (conical, chisel, heat blower and deflector) •  Spare conical and chisel bits also available •  Weight: 78g AH-010 AH-124 Specification Ignition Type Run Time Heat Temperature Max : Self Ignition : 30min : 450°C Part Number Table Description Part Number Gas Soldering Iron Kit, 450°C D03359 Conical Tip for use with D03359 AH-010 Chisel Tip for use with D03359 AH-124 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 07/10/20 V1.0
AH-010 价格&库存
很抱歉,暂时无法提供与“AH-010”相匹配的价格&库存,您可以联系我们找货
