D00310
D00310
    DURATOOL
D00310 数据手册
100 Piece Drills and Bit Set Ì Supplied in a blow moulded carry/storage case Ì Case dimensions (HxWxD): 260x410x90mm Contents: Ì 21pcs HSS Titanium coated drills: 1.0, 1.5, 2.0, 2.5, 3.0, 3.2, 3.5, 4.0, 4.0, 4.2, 4.5, 5.0, 5.0, 5.5, 6.0, 6.5, 7.0, 7.5, 8.0, 9.0, 10.0mm Ì 8pcs Masonry drills: 3, 4, 5, 6, 7, 8, 9, 10mm Ì 8pcs Woodworking drills: 3, 4, 5, 6, 7, 8, 9, 10mm Ì 6pcs Flat wood drill bits: 14, 16, 18, 20, 22, 24mm Ì 4pcs Hole saw: 32, 38, 45, 54mm Ì 1pc Hole saw mandrel Ì 3pcs Drill stoppers Ì 3pcs Drill finders: 3, 4, 5mm Ì 21pcs 25mm length bits: Slotted: 4.5, 5.0, 6.0mm Phillips: PH1, PH2, PH3 Ì Ì Ì Ì Ì Ì Ì Pozi: PZ1, PZ2, PZ3 Torx: T10, T15, T20, T25, T30 Hexagon: 3, 4, 5, 6mm Square: S1, S2, S3 12pcs 50mm length bits: Slotted: 4.5, 5.0, 6.0mm Phillips: PH1, PH2, PH3 Pozi: PZ1, PZ2, PZ3 Torx: T10, T15, T20 6pcs Nut drivers: 6, 7, 8, 10, 12, 13mm 3pcs Hex key: 2.5, 3.0, 4.0mm 1pc Magnetic holder 1pc Screwdriver 1pc 225mm lever model 1pc Centre drill 477637.458024 Price/Set Order Code 136-1388
D00310 价格&库存
很抱歉,暂时无法提供与“D00310”相匹配的价格&库存,您可以联系我们找货
