D00670
D00670
    DURATOOL
D00670 数据手册
Soldering Station Temperature Controlled Soldering Station D00661 D00662 Features: •  •  •  •  •  •  •  Finger tip temperature regulator control (up / down buttons) Safe, low voltage 24V iron operation Integral enclosed stand Pull-out tray that houses the sponge ESD version available Mains on / off switch and fuse Range of tips available Specifications: Power Supply Voltage Electric Iron Power Equipment Power Supply Fuse Regulating Scope of Temperature Temperature Display Display Scope Display Precision Circumstance Humidity Relative Humidity Atmospheric Pressure Shell Size (W × H × D) Weight www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com : 230V (220V to 240V) / 50Hz : 48W : T1 A / 250V (50mm × 20mm glass pipe) : 150° to 450°C : 2 × 3-1/2 grades LCD display : 150°C to 450°C : 5% : +5°C to +40°C : < 85% (not in humidification) : 600 to 1,000HPa : 195mm × 87mm × 155 mm (without electric iron) : About 2,000g Page 08/04/15 V1.1 Soldering Station Temperature Controlled Soldering Iron D00663 Body Diameter 20 Length 198 Body Length 125 Lead Length (m) 1.1 Supply AC Voltage 24 Dimensions : Millimetres Element For Soldering Iron D00664 Sponges Length 71 External Width 41 Dimensions : Millimetres D0065 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 08/04/15 V1.1 Soldering Station Temperature Controlled Tips D00666 Tip Type D00667 Tip Length D00668 Length Part Number 1 Pointed Chisel (45°) Tip Size D00666 0.5 17 3 D00667 65 D00668 Screwdriver 2 D00669 Pointed 0.5 D00670 Dimensions : Millimetres D00669 D00670 Part Number Table Description Part Number Soldering Station, UK Plug D00661 Soldering Station, UK Plug, ESD D00662 Soldering Iron, 48W, 24V D00663 Heating Element for Iron, 88-201A D00664 Replacement Sponge, PK5 D00665 Tip, D00663, 1mm D00666 Tip, D00663, 0.5mm D00667 Tip, D00663, Chisel, 3mm D00668 Tip, D00663, Flat, 2mm D00669 Tip, D00663, Pointed, 1mm D00670 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 08/04/15 V1.1
D00670 价格&库存
很抱歉,暂时无法提供与“D00670”相匹配的价格&库存,您可以联系我们找货
