D00812
D00812
    DURATOOL
D00812 数据手册
ESD Micro-Shear Cutters Description: Maxi-Shear™ Flush Cutter - ESD safe Extremely durable and versatile wire cutter. Tough enough for harnesses and cables with the precision to cut material less than 1 mm thick or work in high density areas. Cutting capacity: 12 AWG (2.0 mm) soft wire. Specifications: 2175AS Overall Length Cutter Type Cut Type Cutting Capacity Max. Cutting Edge Hardness : 148mm : Wire : Flush : 2mm : 20° Description: Music Wire Shear - ESD safe Designed specifically for cutting music wire and other types of hardened wire. Used to cut hardened and tempered steel wire up to 12AWG. Cuts music wire up to 0.040’’ (1.0 mm) diameter. Cutting capacity: 12 AWG (2.0 mm) hard wire. Specifications: Overall Length Cutter Type Cut Type Cutting Capacity Max. : 140mm : Wire : Shear : 2mm 2193AS www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 11/08/14 V1.0 ESD Micro-Shear Cutters Description: Micro-Shear® Flush Cutter - ESD safe Size and shape are optimized to work in high density areas. Rockwell hardness of 55-57 RC. Cutting capacity: 18 AWG (1.02 mm) soft wire. Specifications: Overall Length Cutter Type Cut Type Cutting Capacity Max. Cutting Edge Hardness : 123mm : Wire : Flush : 1.02mm : 20° 410AS Description: Angled Micro-Shear® Flush Cutter - ESD safe Slim profile for accessibility allows easier cutting in difficult areas. Angled head provides excellent sight lines when used in either the vertical or horizontal position. Cutting capacity: 20 AWG (0.8 mm) soft wire. Specifications: 420AS www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Overall Length Cutter Type Cut Type Cutting Capacity Max. Cutting Edge Hardness Page : 130mm : Wire : Flush : 0.8mm : 55° 11/08/14 V1.0 ESD Micro-Shear Cutters Description: Mini-Shear - ESD safe Ultra precise scissor, cuts fine or delicate items with a clean, square edge. Innovative design, advantageous for users with arthritic hands. Cutting capacity: 2  0 AWG (0.8 mm) soft wire. 0.005’’ (0.127 mm) mylar, plastic and shielded cable. Specifications: Blade Length Scissor Type : 20mm : Wire Cutting 440AS Description: Wire Stripper/Cutter - ESD safe Designed to cut and strip all wire sizes from 10-26 AWG. Can be used for both solid and stranded wire. Cutting capacity: 1  0 - 26 AWG (2.59 - 0.405 mm) stranded wire. Specifications: Stripping Capacity AWG Strip Length For Use With : 10AWG : 147mm :2  6-10AWG Solid and Stranded Wires 501AS www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 11/08/14 V1.0 ESD Micro-Shear Cutters Description: Wire Stripper/Cutter - ESD safe Similar to 501AS, but with the added benefit of having wire gauge markings on the cam and a handy closure “hook” that keeps the tool in a closed position when not in use. Model 505AS is designed for solid wire from 12-26 AWG (2.0-0.405 mm). Specifications: Stripping Capacity AWG Strip Length For Use With : 12AWG : 147mm : 26-12AWG Solid Wires 505AS Description: Oval Head Micro-Shear® Flush Cutter - ESD safe Strong and Durable. Size and shape reflect the latest advances in enhanced ergonomics. Cutting edges are an ultra durable 56-58 RC. Cutting capacity: 12 AWG (2.0 mm) soft wire. Specifications: Overall Length Cutter Type Cut Type Cutting Capacity Max : 125mm : Wire : Flush : 2mm 9100AS www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 11/08/14 V1.0 ESD Micro-Shear Cutters Description: Kevlar® Fiber Shear - ESD safe Designed and manufactured specifically for cutting the Kevlar® fiber strength component of fiber optic cables. Serrated edge prevents the fibers from sliding out the front of the shear while cutting. Cutting edges 58-60 RC. Cutting capacity: 1  2 AWG (2.0 mm) soft wire. 030’’ (0.8mm) soft sheet metal. Specifications: Blade Length Scissor Type : 32mm : Kevlar 9180AS Description: Tapered Head Micro-Shear® Flush Cutter - ESD safe Tapered Head version of 9100AS. Improved access in high density areas and added precision. Precision-ground Micro-Shear® cutting edges guarantee a clean cut. Cutting capacity: 14 AWG (1.6 mm) soft wire. Specifications: Overall Length Cutter Type Cut Type Cutting Capacity Max : 125mm : Wire : Flush : 1.6mm 9200AS www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 11/08/14 V1.0 ESD Micro-Shear Cutters Description: Micro-Shear® Flush Cutter - ESD safe Ultra slim profile for access in high density areas. Extra tough high carbon steel blades. Sized for smaller hands and maximum maneuverability. Cutting capacity: 16 AWG (1.29 mm) soft wire. Specifications: Overall Length Cutter Type Cut Type Cutting Capacity Max Cutting Edge Hardness : 124mm : Wire : Flush : 1.29mm : 20° LXAS Part Number Table Description Part Number Cutter, Flush Cutting, 2mm, 148mm 2175AS Cutter, Shear Cutting, 2mm, 140mm 2193AS Cutter, Flush Cutting, 1.02mm, 123mm 410AS Cutter, Flush Cutting, 0.8mm, 130mm 420AS Scissor, Mini Shear, 128mm 440AS Stripper, Wire, 26-10Awg, 147mm 501AS Stripper, Wire, 26-12Awg, 147mm 505AS Cutter, Flush Cutting, 2mm, 125mm 9100AS Scissor, Kevlar Fiber Shear, 145mm 9180AS Cutter, Flush Cutting, 1.6mm, 125mm 9200AS Cutter, Flush Cutting, 1.29mm, 124mm LXAS Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 11/08/14 V1.0
D00812 价格&库存
很抱歉,暂时无法提供与“D00812”相匹配的价格&库存,您可以联系我们找货
