D01826
D01826
    DURATOOL
D01826 数据手册
VDE Safety Belt Kit 9 Piece Specifications: Material Finished : CR-V steel, VDE twin colour grip : Polished Content: 1 1 1 1 1 1 1 1 1 piece piece piece piece piece piece piece piece piece - VDE 180 mm combination pliers - 160 mm VDE diagonal cutting pliers - VDE slot screwdriver 3 × 100 mm - VDE slot screwdriver 4 × 100 mm - VDE Phillips screwdriver PH1 × 80 mm - VDE Phillips screwdriver PH2 × 100 mm cable shears (Electrician sears) - cable knife, VDE handle - tester 120 to 250 V, GS approved Nylon waist bag , black with yellow webbing Each in nylon bag Part Number Table Description Part Number VDE Safety Belt Kit, 9 Pieces D01826 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2011. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com 31/10/11 V1.1
D01826 价格&库存
很抱歉,暂时无法提供与“D01826”相匹配的价格&库存,您可以联系我们找货
