D03361
D03361
    DURATOOL
    DURATOOL - D03361 - Blow Torch, 150 g, 1300 Deg C, 45 x 150 x 65 mm
D03361 数据手册
Gas Blow Torches Features for D03356, D03362 and D03363 •  •  •  •  •  •  •  D03356 D03362 D03363 Piezo auto ignition Safety lock Continuous operation lock Adjustable gas flow Supplied with stand Can also be used in the kitchen for culinary purposes Requires butane gas (not supplied) Specification for D03356 Fuel Capacity : 25ml Features for D03357 •  •  •  •  •  •  •  D03357 Uses a standard butane canister (not supplied) Anti-flare design Piezo auto ignition Adjustable gas flow Immediate shut-off function Safety switch Can also be used in the kitchen for culinary purposes Features for D03361 •  •  •  •  D03361 Uses a standard butane canister (not supplied) Piezo auto ignition Adjustable gas flow Can also be used in the kitchen for culinary purposes Part Number Table Description Weight Height Width Depth Part Number Gas Blow Torch with stand, 1300°C, 40min Run Time 150g 165mm 65mm 105mm D03356 Gas Blow Torch 190g 68mm 55mm 160mm D03357 Gas Blow Torch, 1300°C 150g 65mm 150mm 45mm D03361 Gas Blow Torch with stand, 1300°C, 45min Run Time 262g 180mm 60mm 133mm D03362 Gas Blow Torch with stand, 1300°C, 30min Run Time 212g 160mm 60mm 105mm D03363 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 08/10/20 V1.0 Gas Blow Torches Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 08/10/20 V1.0
D03361 价格&库存
很抱歉,暂时无法提供与“D03361”相匹配的价格&库存,您可以联系我们找货
