1296771+5090726+1467280
    DURATOOL
1296771+5090726+1467280 数据手册
Soldering Station Kit 1296771 – Soldering Station (UK) Feature: • With free solder wire and tip cleaner Specifications: Colour External Depth Height Maximum Temperature Minimum Temperature Power Consumption Voltage, Output Voltage, Supply AC Width, External 5090726 – Lead Free Solder Wire : : : : : : : : : Blue 165 mm 87 mm 450°C 150°C 48 W 24 V ac 230 V ac 195 mm Specifications: Flux Type : 505, Rosin based Lead Free, 99.3% Tin, 0.7% Copper Material Composition : Alloy Maximum Bit Temperature : 370°C Melting Temperature : 227°C Minimum Bit Temperature : 350°C Weight : 0.5 kg Wire Diameter : 0.7 mm 1467280 – Soldering Tip Cleaner Features: • • • • • • Contents made of low abrasive brass shavings No water or messy wet sponges necessary No temperature drop as in conventional sponges Anti-slip pad on the base and an integral adjustable soldering iron rest Two concave indents on the top rim Dimensions (Diameter × Height) : Ø82 × 30 mm Part Number Table Description Part Number Kit, Soldering ST+Wire+Cleaner, UK 1296771+5090726+1467280 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 21/04/12 V1.1
1296771+5090726+1467280 价格&库存
很抱歉,暂时无法提供与“1296771+5090726+1467280”相匹配的价格&库存,您可以联系我们找货
