D00677
D00677
    DURATOOL
D00677 数据手册
Soldering Station Temperature Controlled D00677 D00678 Features: • Finger tip temperature regulator control (up / down buttons) • Safe, low voltage 24 V iron operation • Integral enclosed stand • Pull-out tray that house the sponge • ESD version available • Mains on / off switch and fuse • Range of tips available Specifications: Power supply voltage Electric iron power Equipment power supply fuse Regulating scope of temperature Temperature display Display precision Circumstance humidity Atmospheric pressure Shell size (W × H × D) Weight : 230 V (220 to 240 V) / 50 Hz : 48 W : T1 A / 250 V (50 × 20 mm glass pipe) : 150° to 450°C : 2 × 31/2 grades LCD display Display scope : 150° to 450°C : 5% : +5°C to +40°C Relative humidity : < 85% (not in humidification) : 600 to 1,000 HPa : 195 × 87 × 155 mm (without electric iron) : About 2,000 g Specification Table Description Soldering Station, EU Plug Soldering Station, EU Plug, ESD Voltage Supply (V) 220 to 240 Part Number D00677 D00678 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2011. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 20/09/11 V1.1
D00677 价格&库存
很抱歉,暂时无法提供与“D00677”相匹配的价格&库存,您可以联系我们找货
