D01626
D01626
    DURATOOL
D01626 数据手册
Ultrasonic Cleanings D01626 Description The D01626 a semi automatic wire stripping tool incorporating a flexible jaw cutting edge consisting of a large number of independent leaf blades on as resilient base. These blades surround each conductor by self adjustment thus reducing conductor damage. By using a flexible jaw principle, single, round or flat wires may be stripped with ease. The tool will strip wires up to #15 AWG (1.5 mm2) overall cross-section. Make adjustments using the small screw driver supplied Stripping Depth Adjuster For the normal range of wires the depth adjusting screw (1) should be advanced 3/4 turn (clockwise) from its maximum retracted position (retraction counterclock wise is captivated). Deeper or shallower penetration of insulation is achieved by turning the screw accordingly. Optimize its position so that conductors are not damaged Gripping Jaw Inserts Select jaw inserts (2) according to the gripping surface required Red Pads : Coarse gripping Green Pads : Medium gripping White Pads : Fine gripping For very delicate and thin insulations use the white pads Stripping and Cutting 1. To strip, hold the wire inside the jaws up to the stop (3) and squeeze the handle 2. A cutting blade (4) is provided for wire cropping, fully shielded to protect the operator Stripping Jaw Replacement 1. 2. 3. 4. Remove black cover cap (5) and extract the jaw pivot pin (6) Pull out moving jaw holder (7) Remove old stripping jaws by pulling out the holding rivet within Replace with new jaws and reverse-instructions for re-assembly www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 30/05/12 V1.1 Ultrasonic Cleanings D01627 The D01627 has been designed to remove insulation from wire and cables, ideal for installation electricians. The design of the tool enables the user to strip cable of 6 mm2 (10 AWG) down to 0.082 (27 AWG) with an easy action gripping pad adjuster (A) and blade depth adjuster (B) providing in the one tool what was previously only available by having several. The tool also has a cut off blade (C) handling cable up to 6 mm2 (10 AWG) stranded copper conductor Setting To set the tool for the required cable size, adjust yellow levers as needed. Use these adjusters to set the jaws and cutting blade depth for a clean insulation cut while preventing damage to the underlying conductor. For smaller diameter cables, the gripping pad adjuster (A) is set further back. For thicker or harder insulation, blade depth adjuster (B) is set further forward. The final adjuster settings will be a function of cable diameter and hardness of insulation Operation Once set for the required cable size, the cable is inserted into the jaws of the tool and [he handles squeezed together. The will grip and strip the cable in one action; to release simply relax the grip on the tool at the end of the cycle. Where longer strip lengths are required, the cable may be allowed to protrude from the side of the jaws prior to stripping Technical Information As wires and cables with the same nominal cross-sectional area will vary in diameter according to whether they have solid or stranded conductors, and upon the thickness of insulation, no precise setting table is practical. Incorporates a limiting self adjustment feature by use of a floating lower stripping jaw, safe and accurate stripping will take place across a range of settings Instructions Tool should not be used on live electrical circuits. Not protected against electrical shock Always use CE / OSHA / ANSI or other approved eye protection when using tools Tool is not to be used for purposed other than intended Part Number Table Description Stripper Part Number D01626 D01627 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 30/05/12 V1.1
D01626 价格&库存
很抱歉,暂时无法提供与“D01626”相匹配的价格&库存,您可以联系我们找货
