D03195
D03195
    DURATOOL
    DURATOOL - D03195 - DIGITAL CALIPER, 0.1MM, 150MM
D03195 数据手册
Plastic Electronic Digital Calliper - 150mm Description Electronic carbon fibre composite digital calliper designed for precise and accurate measurements of objects. It is able to measure depth, step, external and internal dimensions with a zero setting at any point along the range. The calliper features both metric and imperial units on a highly legible screen. Features •  •  •  •  •  •  High precision digital readout on clear LCD display Imperial or metric units at the touch of a button Depth measuring blade Step-measuring faces For internal and external measurements Low battery level indicator Part Number Table Description Part Number Plastic Electronic Digital Calliper, 150mm D03195 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Page 05/11/19 V1.0
D03195 价格&库存
很抱歉,暂时无法提供与“D03195”相匹配的价格&库存,您可以联系我们找货
