Wire Strippers
608-369A-F, 608-369B-F and 608-369C-F
Features:
Stripping tools with precision blades strips teflon, PVC, silicone
The tools are made of aluminium with plastic coated handle
Specifications:
608-369A-F
Diameter of Cutting Blade : 0.5, 1.2, 1.6, 2 mm
608-369B-F
Diameter of Cutting Blade : 1, 1.6, 2, 2.6, 3.2 mm
608-369C-F
Diameter of Cutting Blade : 22, 16, 14, 12, 10, 8 AWG
808-080-F
Features:
A versatile wire stripper of sturdy construction capable of
cutting and stripping flexible cable from 0.2 to 6 mm without
any adjustment
Blade pressure can be adjusted for external sheaths of 3 core
cables
Also feature a cable cutter
www.element14.com
www.farnell.com
www.newark.com
www.cpc.co.uk
www.mcmelectronics.com
Page
17/05/12 V1.1
Wire Strippers
808-080-F
Dimensions : Millimetres
8PK-033-F
Features:
Suitable for crimping 1.5 to 6 mm (red, blue and yellow) insulated
terminals
Also used in the tool is a wire cutter, wire stripper, bolt cutter and
position for crimping ignition terminals
8PK-033-F
Part Number Table
Description
Part Number
Wire Stripper, 0.5 to 2 mm
608-369A-F
Wire Stripper, 1 to 3.2 mm
608-369B-F
Wire Stripper, 8 to 22 AWG
608-369C-F
Wire Stripper, 0.2 to 6 mm
808-080-F
Crimp Tool / Wire Stripper
8PK-033-F
Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of
it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces
all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use
made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted.
Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising)
is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012.
www.element14.com
www.farnell.com
www.newark.com
www.cpc.co.uk
Page
17/05/12 V1.1
很抱歉,暂时无法提供与“808-080-F”相匹配的价格&库存,您可以联系我们找货
