972-0070
972-0070
    DURATOOL
972-0070 数据手册
Hand Hole Cutters Features: • • • • A complete easy to use system enabling a wide variety of hole configurations to be punched by hand Suitable for sheet steel, stainless, non-ferrous metals and plastics Ideal for switchgear manufacturers, electricians, plumbers and handi-crafters Heat treated steel punches and dies manufactured to close tolerances will punch burr free holes up to 2 mm thick in steel and 3 mm thick in aluminium The friction reducing thrust bearings make hole punching effortless. Reducing force required by approximately 65% All hole cutters can be used with hydraulic kit 940-0000 Punches and dies are made from case hardened steel to give reduce wear and give long life Special sizes available on request Specification Table Description Pilot Hole Bolt Size Thrust Bearing Part Number Metric Round Sizes Circular Hand Hole Cutter, 12.5mm Circular Hand Hole Cutter, 14.5mm 970-0010 10 8 970-0020 Circular Hand Hole Cutter, 16.5mm 970-0030 Circular Hand Hole Cutter, 18mm NA M10 Circular Hand Hole Cutter, 20mm M10 Circular Hand Hole Cutter, 22.5mm 970-0060 12 10 970-0070 M10 Circular Hand Hole Cutter, 25mm 970-0080 M10 Circular Hand Hole Cutter, 27.5mm M10 Circular Hand Hole Cutter, 30mm 970-0050 14.5 12 Yes 970-0090 970-0100 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 15/11/11 V1.1 Hand Hole Cutters Specification Table Description Pilot Hole Bolt Size 14.5 12 Thrust Bearing Part Number Metric Round Sizes M12 Circular Hand Hole Cutter, 35mm M16 Circular Hand Hole Cutter, 50mm M16 Circular Hand Hole Cutter, 60mm 20 16 970-0110 Yes M16 Circular Hand Hole Cutter, 70mm 970-0130 970-0140 970-0150 Imperial Round Sizes M10 Circular Hand Hole Cutter, 1 1/4 Inches 12 10 M12 Circular Hand Hole Cutter, 1 1/2 Inches 14.5 12 M16 Circular Hand Hole Cutter, 1 3/4 Inches 20 16 14.5 10 10 8 16.5 12 NA Yes 971-0040 971-0050 971-0060 Square Series Sizes M10 Square Hand Hole Cutter, 19.1mm M10 Circular Hand Hole Cutter, 12.6mm M10 Circular Hand Hole Cutter, 15.1mm M12 Circular Hand Hole Cutter, 32.5mm 972-0040 Yes 972-0050 972-0060 972-0070 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2011. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 15/11/11 V1.1
972-0070 价格&库存
很抱歉,暂时无法提供与“972-0070”相匹配的价格&库存,您可以联系我们找货
