973-0070
973-0070
    DURATOOL
973-0070 数据手册
Rectangular Hole-cutters Features: • A complete easy to use system enabling a wide variety of hole configurations to be punched by hand • Suitable for sheet steel, stainless, non-ferrous metal and plastics • Ideal for switchgear manufacturers, electricians, plumbers and handicrafters • Heat treated steel punches and dies manufactured to close tolerances will punch burr free holes up to 2 mm thick in steel and 3 mm thick in aluminium The friction reducing thrust bearings make hole punching effortless Reducing force required by approximately 65% All hole cutters can be used with hydraulic kit 940-0000 Punches and dies are made from case hardened steel to give reduce wear and give long life Special sizes available on request Rad 3.5 1 5.5 3 7 4 The sizes shown are specifically designed to suit all the major electrical cut-outs for switches, panel inserts, fans, etc, but is by know means comprehensive; special sizes can be made to order and included in the range www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 15/11/11 V1.1 Rectangular Hole-cutters Specification Table Size Pilot hole Bolt size Thrust Bearing Part Number NA 973-0030 Metric Rectangular Sizes 15.9 × 13 10 19.3 × 13.1 22 × 19.6 25.8 × 21.6 14.5 27.2 × 22.1 8 973-0050 973-0070 10 973-0090 12 973-0120 27.2 × 12.2 10 8 28.2 × 22.5 14.5 10 28.4 × 11.4 10 8 973-0150 29.4 × 22 14.5 10 973-0160 Yes 34.5 × 24.5 36.9 × 21.1 973-0130 973-0140 973-0180 16.5 12 37 × 21.9 61 × 29 25 16 973-0200 - 973-0210 NA 973-0240 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2011. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 15/11/11 V1.1
973-0070 价格&库存
很抱歉,暂时无法提供与“973-0070”相匹配的价格&库存,您可以联系我们找货
