D00352
D00352
    DURATOOL
D00352 数据手册
Digital Caliper Instructions: • • • • • Before using the digital caliper for the first time, wipe clean the surface with dry and clean soft cloth Always keep the digital caliper clean and dry Never apply electrical voltage onto any part of the digital caliper Do not engrave the caliper with electrical engraving pen Remove battery if the caliper is not used for prolong period Nomenclature I. Step measuring faces 2. Inside measuring faces 3. LCD display 4. Inch / mm conversion switch 5. Slider clamp screw 6. Beam 7. Scale 8. Depth measuring blade 9. Thumb roller 10. Battery compartment lid I I . Zero switch 12. Power ON / OFF switch 13. Outside measuring faces Operation 1. Preparation a. Wipe clean the measuring surface of the digital caliper with dry and clean soft cloth b. Loosen the locking screw and check if all the buttons, switches and LCD display respond well 2. Basic Methods of Measuring a. Make sure the slider clamp screw (5) is loosened b. Press the "ON" button (12) to switch on the unit c. Press the "inch / mm" button (4) to select the unit of measurement d. Close the measuring jaws and press the "ZERO" button (11) to reset the display to zero e. Use one of the following measurement methods to take measurement www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 25/04/12 V1.1 Digital Caliper To Measure Steps To Measure External Dimensions To Measure Depths To Measure Internal Dimensions Battery Replacement Remove the battery compartment lid (10) in the direction of the arrow and replace the battery with the positive side facing out. Close the compartment lid Troubleshooting Symptom Possible causes Measure Frozen display Accidental trouble in circuit Remove the battery and put back after one minute Flashing digits Battery is weak Replace the battery No display on LCD 1. Dead battery 2. Poor battery contact 1. Replace the battery 2. Clean and adjust the battery contact point in the battery compartment Technical Specifications Display Measuring Speed Measuring Range Power Storage Temperature Working Environment Resolution Accuracy : : : : : : LCD Type ≤1.5 m / seconds or 60 inches / seconds 0 to 150 mm / 0 to 6 inches One 1.5 V button cell (Type Sr44) 0°C to 50°C / 32°F to 122°F 5°C to 40°C / 41°F to 104°F (less than 80% Relative Humidity) : 0.01 mm / 0.0005 inches : +0.02 mm / ±0.001 inches (
D00352 价格&库存
很抱歉,暂时无法提供与“D00352”相匹配的价格&库存,您可以联系我们找货
