D01487
D01487
    DURATOOL
D01487 数据手册
Duratool Spacer Features: •  •  •  •  •  •  •  Material Designation Product Description Dielectric Strength Volume Resistivity CTI HVTR D495 Colour Minimum Thickness (mm) : 101(+)(f1), 101F(+)(f1), 101L(+)(f1), E101(+)(f1), E101L(f1), 132F(+)(f1), 135F(+)(f1) : Polyamide 66 (PA66), designated "zytel" furnished as pallets : 13kV/mm : 14 (10k Ω-cm) :0 :0 :6 Flame Class 0.71 All 1.5 3 HWI HAI RTI Elec RTI Imp RTI Str 4 V-2 6 3 IEC GWIT IEC GWFI 725 0 130 75 85 2 750 800 960 - (+) Virgin and regrind up to 50% by weight inclusive, have the same basic material characteristics. (f1) Suitable for outdoor use with respect to exposure to ultraviolet light and water exposure. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 29/04/13 V1.0 Duratool Spacer Dimensions : Millimetres Part Number Table Description Part Number D01486 D01487 HEX Threaded Spacer, Nylon 6.6, Natural D01488 D01489 D01490 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 29/04/13 V1.0
D01487
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:工作温度范围为-20℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、仪器仪表等领域。
7. 封装信息:采用DIP6封装形式。
D01487 价格&库存
很抱歉,暂时无法提供与“D01487”相匹配的价格&库存,您可以联系我们找货
D01487
  • 10+2.39673
  • 250+2.18316
  • 500+2.04078
库存:16436
