D03406
D03406
    DURATOOL
    DURATOOL - D03406 - Battery Tester, Lead Acid, Li-Ion, 8V to 30V, 120 mm, 75 mm, 20 mm
D03406 数据手册
12V Lead Acid & Lithium Battery Tester Key Features •  T  ests 12V sealed, lead acid batteries down to 2Ah and 12V Lithium   batteries for vehicles, motorcycles and scooters •  Accurate results in milliseconds •  Battery life analysis vehicle and scooters •  Analysis result: Good or Replace •  Large easy to read LCD display •  Test results based on JIS, EN, DIN, SAE and IEC standards •  Languages: English, German, Spanish, French, Dutch, Italian •  Vehicle cranking system test - cranking time, voltage and status •  Vehicle charging system test - load voltage, unloaded voltage, ripple status and charging system status •  Store the testing result •  Print function via PC printer This battery tester is designed to test the condition of the automotive battery using conductance method. Unlike the   conventional method of draining the battery by applying resistance load to it and obtain the result from the meter gauge; this analyser utilizes a series of pulsed voltage across the battery cells and observes the AC current that flows in response to it. The benefits of this test method are: Conductance correlates directly to the battery capacity Passive testing method is safe Never discharges or drain the battery Tests the condition of discharged battery Consistent and repeatable results Provides unique indication of battery conditions Checks alternator charging and starter cranking conditions Maintenance-free and no internal batteries required Powers up when connected to the battery posts during testing Functionality: Test Result: Good or Replace Capacity - Cold Cranking Amps (CCA), DIN, EN and IEC information relative to battery rating. Internal resistance value (mΩ) / Life in percentage (%) / Cranking system / Charging system Application: Use to test a wide range of 12V batteries (Starting [SLI], Deep Cycled and Marine) of Wet (Flooded), VRLA or Maintenance Free (MF), Sealed Maintenance Free (SMF), Absorption Glass Mat (AGM) and GEL cell. Lithium-ion batteries, The major battery standards JIS, SAE, EN, DIN and IEC are supported. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 15/01/21 V1.0 12V Lead Acid & Lithium Battery Tester Operating Parameters: System voltage: 12 Volts, Input voltage range: 9V to 15V Power requirements: No internal batteries required. Power on when hooked up during testing. Testing Range: Lithium-ion - CCA/BCI/CA/MCA/ EN/SEA-20-1000, DIN/IEC-20-700, GB-2-120 Ah Lead acid - CCA/BCI/CA/MCA/ EN/SEA-20-2000, DIN/IEC-20-1400, GB-2-220 Ah Battery Testing Range Scooter Vehicle CCA 20-1000 CCA 20-2000 BCI 20-1000 BCI 20-2000 CA 20-1000 CA 20-2000 MCA 20-1000 MCA 20-2000 JIS 26A17-150F51 JIS 26A17-245H52 DIN 20-700 DIN 100-1400 IEC 20-700 IEC 100-1400 EN 20-1000 EN 100-1400 SAE 20-1000 SAE 100-1400 GB 2-120 GB 30-220 Part Number Table Description Part Number Lead Acid & Lithium Battery Tester, 12V D03406 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 15/01/21 V1.0
D03406 价格&库存
很抱歉,暂时无法提供与“D03406”相匹配的价格&库存,您可以联系我们找货
