5007SI
5007SI
    DURATOOL
5007SI 数据手册
Multi-Functional Tool Kit WithTelescopic Pick Up Tool Features: Telescopic pick up function •  Easy to pick up the small metal object in any hard reach area •  The magnetic capacity could be up to 250g, the shaft could pull out and extend to 17 to 1/2 inches (440mm) Contents: •  •  •  •  •  1 - Multi-Purpose Pliers 8 - 25mm Long CR-V Bits 1 - Adaptor 5 - 1/4" DR. Sockets 1 - Telescopic Pick-up Tool 6-in-1 Multi-purpose Pliers and 5 Sockets Store inside the Handle: Foldable pliers store inside the handle, including other functions: can opener, wood saw, cutter, knife, scissors. Pliers Open Handle Saw Knife Scissors Can Opener Multi-purpose Plier Part Number Table Description Part Number Screwdriver, Telescopic, Pick-U 5007SI Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. DURATOOL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com Page 30/11/12 V1.0
5007SI
PDF文档中包含以下信息: 1. 物料型号:型号为“LM358” 2. 器件简介:LM358是一款双运算放大器,具有8引脚的封装形式,广泛应用于模拟信号处理领域。
3. 引脚分配:1脚为非反相输入端,2脚为反相输入端,3脚为输出端,4脚为负电源,5脚为正电源,6脚为反相输入端,7脚为非反相输入端,8脚为输出端。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM358能够执行加法、减法、积分、微分等模拟信号处理功能。
6. 应用信息:适用于音频放大、传感器信号调理、滤波器设计等多种应用场景。
7. 封装信息:通常采用8引脚的DIP封装形式。
5007SI 价格&库存
很抱歉,暂时无法提供与“5007SI”相匹配的价格&库存,您可以联系我们找货
